Budget Head Question
Old Sep 11, 2006 | 08:55 PM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Budget Head Question
A little overview:
I'm using my stock LS1 heads with stock valves. I am getting the heads ported and polished with a 5 angle valve job. I'm running Comp Cams 918 valve springs and the cam specs are:
Basic Operating RPM Range: 2,000-7,000 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Intake Duration: 273
Advertised Exhaust Duration: 279
Advertised Duration: 274 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.581 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.588 in.
Valve Lift with Factory Rocker Arm Ratio: 0.581 int./0.588 exh. lift
Lobe Separation (degrees): 114
The question is...I want to use my stock valves and not upgrade to the stainless steel solid valves...Will the stock valves be able to handle the spring pressure of the 918's...Has anyone ever dropped a valve into the motor???
Old Sep 11, 2006 | 09:45 PM
2004SpiralGrey
bump
Old Sep 11, 2006 | 11:10 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
you won't have any problems with 918's on stock valves.... now turning the motor all the way up to 7k w/ 918's might not work so well....
Old Sep 11, 2006 | 11:53 PM
2004SpiralGrey
i'll be keeping it below there i think i might only take it to about 6250 - 6500
thanks
Old Sep 12, 2006 | 02:53 AM
minytrker's Avatar
minytrker
I would have just bought a set of ls5 heads before doing all that to a set of ls1 heads.
minytrker's Avatar
minytrker
I would have just bought a set of ls6 heads before doing all that to a set of ls1 heads.
Old Sep 12, 2006 | 12:26 PM
2004SpiralGrey
i actually was thinking of going with LQ4 heads to open up the combustion chamber a little but before i researched it i already gave my machine shop my heads
To Budget Head Question
