Paging C5 Cemo
Old Sep 12, 2001 | 01:15 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Paging C5 Cemo
I notice you recently replaced your clutch with the Z06 setup.....how does it feel compared to stock?? Is it easier to break loose the tires when powershifting?? Why did you replace the slave - should I do that too?? Thanks for the input....
Old Sep 12, 2001 | 01:46 PM
C5Cemo's Avatar
C5Cemo
Default Re: Paging C5 Cemo (OliverM5)
How does it feel compared to stock??
There is barely any noticeable difference between the two. At first, the new clutch engaged a little higher up on the pedal but that was it. Pedal weight is exactly the same.
Definitely. The added clamping force is very noticeable esp. when powershifting and spraying at the same time. My orig. clutch would slip a bit, not anymore with the '01 spec.
Yeah, I would highly recommended doing so. The slave cylinder is easily damagable esp. if you like to powershift. Reports of the pedal sticking to the floor on hard runs are quite common. Besides, the cost is cheap and it'll be unbolted when replacing the clutch anyway.
:cheers:
