car is still dying... someone help...
Old Sep 12, 2006 | 11:02 PM
Sully1882's Avatar
Sully1882
Default car is still dying... someone help...
ok...here it goes... 2000 A4 coupe 60,000 miles that have been extremely babied. I began to notice dead battery problems about a month or two ago and if the car sits for a day it is slow to start and then dead after two days of sitting. I have taken the car into Napa, autozone, and O'reilly's and they all said it was the alternator. replaced the alternator and started getting a "charge system fault". Took original alternator into a rebuild shop and they said it tested out just fine. Put the old alternator back onto the car and charge system fault went away but still having problems with the electrical systems... no lights left on, no noises of clicking switches or anything else. Any ideas or do I need to go and buy an ampmeter and try to test the battery for drains?
thanks so much in advance,
Sully
BC... as always you attention is greatly appreciated!
Old Sep 12, 2006 | 11:18 PM
mfrejek's Avatar
mfrejek
You didn't mention the battery. I assume you've already replaced it.
Old Sep 13, 2006 | 08:32 AM
Tom/99's Avatar
Tom/99
You didn't say how old the battery is. A bad battery may be the problem.
Old Sep 13, 2006 | 08:39 AM
Sully1882's Avatar
Sully1882
Default battery
when i took the car into Napa, Autozone, and Oreilly's they all checked the battery and said it was perfectly fine.... that's when i tried replacing the alternator. The battery is only two years old.
Old Sep 13, 2006 | 09:18 AM
timemender's Avatar
timemender
I would bet on the battery being the problem.
If your Vette is not a daily driver, fully charge the battery, then immediately disconnect the ground cable to the battery. Let it sit for two (three? – four?) days then reconnect it and try to start the car. This is the cheapest testing method to determine if the battery has an internal draw and is running itself down – but time consuming – and not practical on a daily driver.
Or – Run out and buy a new battery – but don’t trade in the old one for the “core deposit” as the old battery may prove to be good.
The age of the battery means nothing. The battery could have been mishandled some time in the past – dropped or set down hard for example.
As far as the rebuild shop is concerned, I would assume that they did a proper test as it would be in their self-interest to find your alternator defective.
Old Sep 13, 2006 | 09:23 AM
Hatdude's Avatar
Hatdude
My bet's on the battery too.
Old Sep 13, 2006 | 09:30 AM
MNCrystalRed2011's Avatar
MNCrystalRed2011
When I had my battery go out, the Chevy dealer I stopped at put their meter on it and it showed OK, but the car wouldn't crank over. Put a new battery in and voila, started with no hesitation.
Old Sep 13, 2006 | 10:58 AM
jimcork1's Avatar
jimcork1
The test on the battery did not test all the capability of the battery. Too bad you spent the $$ on the alternator. I always look at the battery first. 99 Nassau Blue
Old Sep 13, 2006 | 01:30 PM
Sully1882's Avatar
Sully1882
Default ok hold on...
I only bought the new alternator when I pulled the battery and took it to NAPA and autozone and OReilly's and they did test the battery with and without a load. It tested just fine. So then I put a new alternator on while I took the old alt into get rebuilt. When I took it into the shop they tested the alt and said it was just fine...so i amkinda at a lost... thank for the ideas so far...
thomas
Old Sep 13, 2006 | 02:26 PM
mfrejek's Avatar
mfrejek
can you just sway out the battery with one from another vehicle? This isn't rocket science.......yet
Old Sep 13, 2006 | 03:20 PM
patton's Avatar
patton
St. Jude Donor '09
did changing the alt solve the dead batt issue aside from the dic message.while an alt can test good for output they can also drain a batt while car is off
Old Sep 13, 2006 | 03:50 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Damn sully hope it works out for you. I would not trust crack heads at the auto parts store. They could see +12VDc from alternator, but not the load leak like above. Good luck brother, any members local??? Give a brother a hand???
Dave
Old Sep 13, 2006 | 06:01 PM
Sully1882's Avatar
Sully1882
Default alt change
when i put the new 110 amp alt in the DIC gave me the "charge system fault" message. Once I put the old alt back into the car the message has not been seen since. Just have problems with the battery drain when car sits for more than 1 day.....
Old Sep 13, 2006 | 06:17 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Change the battery. Although it might not be dead YET, many problems on a C5 are related to a low battery. I usually swap my battery every 2 years.
Old Sep 14, 2006 | 02:21 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default dead again
hey I got some info.
rig up an ammeter that you can clip onto the battery negative post between the battery and the negative battery cable. if everything is off, after the interior lights go off, and there is an electrical drain, you will see it on the ammeter.
next, go to the battery connection on the alternator and put it there, between the battery stud and the battery lead. put the battery cable back on, and check the ammeter. If no ammeter reading, put the ammeter back on the battery negative cable, and start pulling fuses till the drain is gone, and then troubleshoot that system.
Old Sep 20, 2006 | 01:50 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I'm having nothinf but problems with my Z. My alternator was actually pooched...I died in the centre lane of 3 lanes. Towed home, trailered to the shop, no charge at all...alternator replaced and I a few days later I had charge system fault but the system is charging fine when hooked up. I am on the 2nd replacement battery at n/c. Had it in again on Monday, of course the fault code wouldn't come on...it was dead again this morning.
Old Sep 20, 2006 | 03:38 PM
Jackal's Avatar
Jackal
Its a battery, 98% sure of it.
To car is still dying... someone help...
Old Dec 7, 2006 | 07:42 PM
Sully1882's Avatar
Sully1882
Default found something new, same old problem
ok drove my truck today after drivinng the vette yesterday...pulled up behind the vette in the driveway and noticed that the DIC was active and showing the mileage.... i think this maybe what is causing my battery drain.... anyone have any ideas? I mean I know this is probably my drain but why is this intermitantly doing this? Could this still be a problem with the BCM not going into sleep mode? Anyone have any ideas? I'm all ears again... and yes it has a new battery now.... 2 months ago...
Old Dec 7, 2006 | 07:54 PM
dpd's Avatar
dpd
see if the bcm has been under water[clogged a/c drains,etc].unplugg the connectors and see if you see green corrosion on any of the connectors or bcm pins.
Old Dec 7, 2006 | 08:09 PM
Sully1882's Avatar
Sully1882
Default where's the BCM
isn't the BCM located under the carpet on the passenger's side? Damn i hate going out there now b/c it's like 20 degrees here in NW Arkansas... but inn two months my new house will have a heated garage... that would be nice right now! I will check the BCM right now!
Thomas
