ls1/ls6 conversion to ls2 post???
Old Sep 12, 2006 | 11:37 PM
dvandentop's Avatar
dvandentop
Default ls1/ls6 conversion to ls2 post???
does anyone have all the info in one thread to show how to convert from the ls1/6 motor to the ls2?? I am just needing what sensors and wiring etc need to be done.
thanks alot!
Old Sep 12, 2006 | 11:51 PM
msghuff's Avatar
msghuff
Are you talking about the entire motor or just the block?
If it just the block then you will need to relocate the knock sensors and use a extended harness. And the Cam position sensor is in the front so you will need to get the extended harness as well.
If its the entire motor you will need an adapter for the TB as well.
Old Sep 12, 2006 | 11:52 PM
dvandentop's Avatar
dvandentop
well i will be reusing my ls6 intake and throttle body fuel lines etc... i is pretty much the whole shortblock but will have the heads on it already too.
any idea on where to get the extended harness??
thanks alot
Old Sep 12, 2006 | 11:54 PM
msghuff's Avatar
msghuff
SDPC off to the left will get you everything you need.
Old Sep 12, 2006 | 11:59 PM
dvandentop's Avatar
dvandentop
excellent see my fun project here! i think this ls2 for 2700 shipped will be cheaper then redoing my motor.
http://sio.midco.net/dvandentop5/vmotor/
Old Sep 13, 2006 | 12:11 AM
msghuff's Avatar
msghuff
Dang.......what happened looks like an f-body went for a swim?
Old Sep 13, 2006 | 12:13 AM
dvandentop's Avatar
dvandentop
cts-v actually oh well good deal of money ahead
just needing to get motor figured out on what i all need then i am full steam ahead on getting her on the road
To ls1/ls6 conversion to ls2 post???
