99 FRC, misfire problems - please help!
Old Sep 17, 2006 | 07:06 PM
  #41
torchredfrc's Avatar
torchredfrc
Originally Posted by zo6vetteman2003
You pulled the plug ground connectors apart and there wasn't any corrosion at all?
Actualy no but I added fog lights to the car about a year ago and used G101 & G102 for the ground on the lights. In the process my G101 had some corrosion and I took it out, retapped the frame and put a bolt there. All I did this time was a visual inspection and there was not visible corrosion.
Old Sep 18, 2006 | 04:01 AM
  #42
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Swaping the coils / injectors on #2 seems reasonable.. Arrgh, wish you had a compression gauge, that would rule our any mechanical issues once and for all.
Old Sep 18, 2006 | 08:04 PM
  #43
Dan_the_C5_Man
C'mon bud, the suspense is killing us! So what happened with the part swaps?
Old Sep 18, 2006 | 10:16 PM
  #44
muncie21's Avatar
muncie21
Matt, If you don't get it fixed by this weekend let me know. I've got a compression tester I can drop by. My car is a 99 also, I'm sure between the two of'em we should be able to figure this out.
Old Sep 19, 2006 | 10:29 AM
  #45
torchredfrc
I'm having some out patient surgery today so I didn't get to test the swap. Muncie, that would be excellent. If you do end up heading down I'll let you take the headers home with you!
Old Sep 19, 2006 | 07:09 PM
  #46
LoneStarFRC's Avatar
LoneStarFRC
A simple vacuum gauge would help too. What does spark plug #2 look like?
Robert
Old Sep 20, 2006 | 03:02 AM
  #47
torchredfrc
Robert
Looks gas fouled. All the plugs did. I'm going to work on leaning the tune out at idle once I get this misfire problem solved.
Old Sep 20, 2006 | 07:58 PM
  #48
LoneStarFRC
I'm surprised your not throwing a P0300 code and a flashing CEL too. Too much fuel, if not corrected quickly enough, is really bad for catalytic converters. Not to mention the whole cylinder "washdown" thing too.
Old Sep 20, 2006 | 11:33 PM
  #49
torchredfrc
Yes, obviously running it way to rich. I did get a flashing service engine light with the misfires as well as the P0300 code. As far as catalytic converters - I don't have any on the car at the moment. Once I get the tune leaned out and corrected I will be putting converters back on the car. I am aware of the washdown issue. Thanks, good information!
Old Sep 21, 2006 | 01:14 AM
  #50
muncie21's Avatar
muncie21
If you haven't already, you should take a second to read the troubleshooting tree for code P0300 here: http://www.gearchatter.com/viewtopic10049.php
Also, from what I can recall, if the PCM detects a specific cylinder is misfiring the code P0300 will increment based upon the cylinder. For example if cylinder #4 is misfiring you'll get code P0304, code P0307 for cylinder 7 etc.
Based upon this info, I'm inclinded to believe you have a single problem affecting all cylinders.
Old Sep 21, 2006 | 08:43 PM
  #51
muevet's Avatar
muevet
Navigator
Default misfire
This sounds a little like a problem I had with my 03-Z06. This misfire came and went and also changed sides (banks). A member on this forum suggested that the wiring harness to the injectors might be damaged, that was his problem. After telling this to the warranty dealer, they dismissed my sugestion for 6 months. When all else failed, they tried replacing the harness and my Vette has run great since then.
Old Sep 22, 2006 | 09:26 AM
  #52
torchredfrc
I've visually inspected the wires and will I don't believe they are bad I've still got my fingers crossed that they are not bad. Do you know what all was replaced when they redid your wiring? It would be quite a job if you had to replace the entire wire harness.
Old Sep 23, 2006 | 01:32 PM
  #53
Dan_the_C5_Man
So what ever happened with the parts swapping exercise?
Old Sep 23, 2006 | 03:55 PM
  #54
muevet's Avatar
muevet
Navigator
Default wiring harness
Here is what they told me. They can check for the miss and charge the time, but they had to get factory approval to order and replace the part under warranty. The fix was quick once "they" found the problem.
Old Sep 23, 2006 | 03:59 PM
  #55
Evolution's Avatar
Evolution
How long has the cam been in?
Old Sep 23, 2006 | 09:56 PM
  #56
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I believe the area that was referred to is the fuel rail bracket on the drivers side, the harness is bolted to the head and sometimes will chaffe on the bracket
Old Sep 24, 2006 | 02:30 PM
  #57
torchredfrc
I switched coil pack #2 with #4 - no change. I also moved the injectors from bank #2 to bank #1 and didn't notice any difference. muncie21 in his tuning genius pointed out a few status bits to me that I was previously unaware of. Turns out my emulated narrowband and potentially other parameters were stopping the car from entering closed loop. Once he got it in closed loop we were able to lean out the idle and take it for a few test drives. Car drives like a champ now.
Next step... since muncie21 went home with my headers, I'm ordering another set of LG Pro LT's (with cats this time) on Monday and I'm going to see if they will weld in a extra O2 bung so I can run 2 stock narrow band sensors as well as my wideband w/o emulation. I will also be purchasing 2 new narrowband O2 sensors since my driver's side sensor now looks lazy and isn't switching very well.
To 99 FRC, misfire problems - please help!
  #58
torchredfrc
Long time, >1.5 years.
Old Sep 25, 2006 | 01:12 AM
  #59
muncie21's Avatar
muncie21
BTW, we did a compression check on the suspect cylinder (#2) and it's adjacent brother, #4. Both were around 155 or so.
I will pose this question on the HPT forum, but I figure I'll start here first as I'm sure there are people here that are interested also. Here's the question:
What exactly does the cylinder balance test do/so?
When torchredfrc did this test, it showed cylinder #2 as being significantly different than the rest---~60 vs. ~90-100'ish for the rest. But in subsequent testing we could not find any issues with that cylinder. Coil packs were changed, ignition wires were ohm'ed, spark plugs checked, injectors changed, compression tested, etc......
Old Sep 25, 2006 | 11:38 PM
  #60
muevet's Avatar
muevet
Navigator
Off topic. I just noticed you guys were both in NM. I'm in El Paso.
Are you NCCC members? There is some autocrosses in Albuquerque this weekend.
