THUMP when slowing down.
Old Sep 14, 2006 | 03:27 PM
Kale's Avatar
Kale
Default THUMP when slowing down.
When slowing down, (and sometimes driving real slow) there is a distinct THUMP that seems to come from the rear of the car. It's not consistent at all.
anyone familiar with what this might be?
just to add, this SEEMS like it started after my trans fluid was changed.
Old Sep 14, 2006 | 03:32 PM
Ryan L's Avatar
Ryan L
http://forums.corvetteforum.com/show...8&postcount=26
Old Sep 14, 2006 | 05:28 PM
Kale's Avatar
Kale
not a click, a thud. like slamming your hand on a wood desk.
Old Sep 15, 2006 | 10:14 AM
Kale's Avatar
Kale
maybe its a bad muffler bearing.
Old Sep 15, 2006 | 04:08 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default thump
I have something like what your describing. mine is a 2001 coupe, and it sounds like the shock top nut is loose I have to find the time to get the shock out and check it
on mine, when i step on the brake with no bumps in the road, it's quiet, but when there is a bump, it's like the gas in the shock keeps the shock in place on the compression stroke, but when the car goes back up to it's rebound, the shock can't compensate fast enough, and there is a thud. mine is a 6 speed, and if I stop, and it does it, starting again like reseats the problem and then it does it again on a larger bump.
If you figure it out before i get the shock out, let me know.
oh by the way, my noise is associated with the right rear because bumps on the left rear don't make that noise. I purposely drove over left bumps and right bumps to differenciate the sides. but at first, i thought it was brakes, then looses gas tank, then found an oilcanning panel right behind the right seat(the one that's covered with carpet?) then I thought it was a loose panel under the car and slid a mirror under the car taped to a broom handle, and everything looks showroom nice, so that wasn't it, soo that's how i started going over bumps wierdly to see what I could find. I even had someone let the clutch out in first and reverse with me laying on the ground next to it with a bright light also.
chris
Old Sep 15, 2006 | 06:40 PM
Kale's Avatar
Kale
now that you mention it, i ALWAYS notice it pulling over a curb...
Old Sep 21, 2006 | 04:57 PM
coupeguy2001
Default thump
did you find anything yet?
I noticed that the r/h aft lower rear control arm bushing bolt looks like it might move just a tiny
Old Sep 22, 2006 | 12:47 AM
jjvet's Avatar
jjvet
Squirrel ?
Old Sep 28, 2006 | 05:02 PM
coupeguy2001
Default noise
did you figure it out yet?
To THUMP when slowing down.
