My C5 came with an exotic K 40 set up which is great; interesting alert sounds, and covers front and rear. The problem is that I dislike the front license plate mount which resembles an "ez pass" unit. Can I remount this elsewhere like in one of the openings by the fog lights?
The unit covers other radar bans also which is my main concern here in north Jersey. Any suggestions or comments are greatly appreciated!
I was going to put a laser diffuser on a while back but can't seem to save enough money as crap keeps braking on my car.
I used to be on a great website that would be much better in answering your questions.....here it is
Your thread mentions laser diffusers and then radar. These are two separate and distinct entities that have completely different applications. Jamming radar is illegal in most places. They use laser here where I live and shifting a laser is not illegal. I mounted my two fronts in the foglight area and put the grill over to hide them from you know who. The rear is on the license plate and looks like the frame.
Nick, I'm also in north Jersey and have a K40 laser defuser that is mounted on the front plate. I went with that setup since I didn't want the screens cut on my Z06 (laser jammers don't work behind the screens according to every installer I've talked to). But if your fog light areas are open, those locations may be an option for you.
I used Reed Audio in Glen Rock - they were very professional and did a great job. If you're close enough, I'd call or go over there and ask them if they could do it for you or what their opinion is of mounting it in the fog light openings (they are an authorized K40 installer). I know other brands of laser jammers can go there, but the K40 may lose its effectiveness if it's not mounted on the front plate because of its design.
Thanks SMR maybe I will try them. I realize I may loose some efficiency in relocating it, but I'm concerned if it is illegal it is too visible where it is....
Laser Jammers and Radar Jammers are illegal in the states of Nebraska, Minnesota, Utah, California, Oklahoma, Virginia, Colorado, Illinois and Washington DC.
I think radar jammers are illegal everywhere, but you're good to go with a laser jammer unless you're planning on some long road trips....
Your pic looks like an Escort Laser Shifter. I have the same unit with the transducers mounted the same way as you. Mine has "assisted" me on two occasions.
BTW, active radar jamming is/has been illegal anywhere in the U.S. for a very long time due to the Federal law. It's almost never enforced by the FCC (the enforcement agency) since they have other fish to fry and very few people dedicated to enforcement of something like this anyway. They would (and should) probably get involved if there was jamming involving anything related to national defense and/or national security. 'Course the FBI would be all over that scenario too.
Active radar jamming of speed enforcement will almost always come under a particular state's jurisdiction as well, and they will (and do) enforce that situation.
Laser jamming is not a Federal violation, but a few states do have it on the books apparently.
Good luck
Mine work just fine and I haven't cut the screens either.
I like the mount by the fog light and will probably do the same, thanks!!
Put the screens back in and nobody can tell what's going on
The fog light area is slanted and it's extremely important to aim the diffusers perfectly straight. You might have to shim the one side to get them aiming straight.
Two are absolutely necessary if you mount them anywhere near the foglights. From what I understand, most cops aim for the front plate. Luckily, aiming a pencil eraser-sized beam steadily from a long distance by hand is not easy. So although the front plate area IS optimal, having two at the sides is fairly effective.
At 1000' (the common distance that most LEO's begin shooting), that "pencil eraser-sized" beam is approx. 3 feet wide.
When installed as per their instructions, Escort's two transponders create an overlapping pattern in front of the vehicle which more than covers the front plate. They are however, horizontally polarized, and need to be very level when installed, but that's not too difficult to accomplish as oahuyahoo points out.
I, for one, would never mount the transponder units behind any kind of grill/screen as that will almost certainly greatly diminish their effectiveness.
A laser widens at travels distance? I did not think that this happened with laser light. Laser light is orderly, matched wave of lights so that it does not disperse like oher forms of light. I am not a physicist but I believe if the cop hits your front plate and your diffuser is to the right and left of the plate. . . youv'e been had.
I have a K40 system but the laser diffuser looked terrible on my C5 so I did not buy it. Would like to paint it or mask it some other way in order to get it.without ruining the look of the car. A front plate is bad enough.
They make a cover for the license plate. Pretty sure its called "LaserShield"
Yes. Laser light widens with distance. The amount of spread may vary depending on things like, atmosphere, power levels being transmitted, etc. They definitely spread much less than conventional "white light", but they do spread.
The types used by LEOs is a relatively low powered, battery operated, portable device and suits law enforcement speed detection purposes well, while at the same time keeping costs down too. Now if LEOs were using the types of laser found in say, the Argonne National Labs or something, your right. You would be dead meat at many miles of range.
Looked up Dirty Howie's License Plate Laser Shield. Would probably be of some help. The plate is what they aim for but I doubt it is all they need to get a reading. The cops obviously aim for the plate and that is why an active Laser Diffuser needs to be near the center. Wish there was a way to mount a diffuser on or about the plate without ruining the look of the car. I am going to go buy some eye glasses to protect me from the Argonne Laser. . . ouch.
He'll just hit the hood which is what he told me he did when I got nailed with the C5 Creations bra on but before I got my K40. So I got the K40, returned the C5 Creations bra, and got a Colgan bra with the front plate cutout. I've been nailed twice since then and it jammed his gun - no tix.
