Need Advice
Old Sep 14, 2006 | 11:18 PM
OUR "97"'s Avatar
OUR "97"
8th Gear
Default Need Advice
As i wrote several day's ago my VETTE is in a p.garage it's safe there,put new batt on it, cleaned the the bat. cables, let the thing set for 20 min berore re-connecting batt, the column lock came on again, reset codes from dic, started the column lock on again, pull the panel off where the "k harness" was suppose to be so to replace the relay,cannot find the harness kit, will look again later I have the gm recall bulletin with pn#and a set of instructions to where it should be located it's not there. Should i call a gm rep. and have him see the car where it is or just call a lawyer just want to fix it but the dealer if it's not there dosen't need to get by with this? Thanks
