tran/clutch question?
Old Sep 15, 2006 | 02:59 PM
jam6252's Avatar
jam6252
Default tran/clutch question?
With original clutch and 34k miles and est. 450rwhp and 430rwtq, under full 1/4 mile drag conditions I am getting a grind at the tail end of shifting into second and same with 3rd. Plus, clutch wants to hang down and not release after the gear change. These are full accel. shifts at 6200 to 6500 rpms. Any tip or suggest would be appreciated. Thanks, John
Old Sep 15, 2006 | 05:51 PM
97C5ENVY's Avatar
97C5ENVY
Sounds like the dreaded clutch line "restrictor" problem. Or possibly bad clutch fluid..or both.
If you are not familar with the "restictor" issue do a search here on the forum and you'll find tons of info.
