lowering question from a newbie
Old Sep 15, 2006 | 10:48 PM
va-c5's Avatar
va-c5
Default lowering question from a newbie
i'm going to lower starting with the rear i have read all the diy info here but i still have 2 questions....
1)what is the torque for the nut on the rear ?
2)everything i have read tells me to jack the car up to remove the load on the rear wheel and tires...what would happen if one was to lower without taking the load off and just lowering it to the clip on top on the bolt?
thanks for your help on this one .................
Old Sep 15, 2006 | 11:25 PM
jeanlucpicard's Avatar
jeanlucpicard
First - No torque, the nut has a nylon sleeve.
Second - Not even Arnold S. could rotate that nut without a jack to take the tension off the nut.
