ground clearance
Old Sep 16, 2006 | 07:08 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Default ground clearance
I am trying to buy a jack that will work on my car with the jacking pucks. I have found a scissor jack (GM) that will work with 4 1/8" clearance. I checked my clearance with a jacking puck and it was about 5 1/8.'' If I have a flat, my clearance would be lower. I bought my vette used so I am not sure if it was lowered. Does anyone know what the clearnce should be? Is there a jack out there that will work with less than 4 1/8?"
Old Sep 16, 2006 | 08:08 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Check E-Bay. Use "racing jack" in search box. There is a low profile (blue & silver) which min heighth is 3 1/4". I have one very similar and it works great with lifting pucks. I bought mine at GI Joes in Washington state for $99.00. Hope this helps.
Old Sep 16, 2006 | 08:14 PM
brucemoose2's Avatar
brucemoose2
I have a "3000lb capacity Harbor Freight aluminum racing jack". The website claims 3" minimum height. The box claims 3.5" minimum height. The actual minimum height is less than 3.125", including the rubber pad on the jack. This jack happens to be on sale right now for 79.99 in the store nearest me. You can get it for 84.99 on the website.
http://www.harborfreight.com/cpi/cta...emnumber=91039
Old Sep 16, 2006 | 08:21 PM
BanditDude's Avatar
BanditDude
Mine is about 5 1/8" to the frame, and I'm fairly certain that it's stock. I use hockey pucks (double thick) and cannot really get a jack underneath the front w/o ramps.
I have a Craftsman 1.5 ton aluminum that comes in at 3 3/4" ($100). I did find one on a web search that's 2 1/2", but I do not know the quality (Astro Pneumatic, for $150). I'm sure that there are others out there.
Good luck w/ your search.
Old Sep 16, 2006 | 10:31 PM
crawfish333
CI 6-7 & 9 Veteran
Thanks for all of the great responses. I will try Harbor Freight and see if I can get one of the "racing jacks."
This forum always comes through for me, thanks again!
Old Sep 16, 2006 | 11:22 PM
TEXHAWK0's Avatar
TEXHAWK0
Be careful about buying Harbor Freight jacks. I have heard of quality problems and even failures.
I have a couple of AC Hydraulics that easily go under my Z06 even with extra thick jacking pucks.
Expensive, but the quality is the best. The DK13HLQ has an extended reach at only 3.1" height.
http://www.asedeals.com/hydraulicjacks2.html
Old Sep 17, 2006 | 12:20 PM
debmwb's Avatar
debmwb
Also if you already are not using them...build a set of ramps. Most of us are using 2x10's or 2x12's with one, two, or three layers stacked in an offset fashion to drive up on so the jack will fit. Works great on lowered Vettes!
Old Sep 17, 2006 | 10:31 PM
crawfish333
CI 6-7 & 9 Veteran
I have some ramps so it is no problem jacking the car up at home. The reason I am looking for the minimum clearance jack is that I no longer have "run flats" and I need a jack for emergency road repairs. (I have plug kit, small compressor etc. already, just need a jack)
Old Sep 18, 2006 | 12:54 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/show....php?t=1502244
Old Sep 18, 2006 | 01:05 PM
rws.1's Avatar
rws.1
I use a 12V plug in electric jack from Walmart... under $40.
Old Sep 18, 2006 | 05:11 PM
FKING1's Avatar
FKING1
I've had one of Harbor Freight's racing jacks for a couple years. Use it all the time. No problems yet.
Fred
To ground clearance
