I had a friend order in a case of amsoil for me. I thought I was getting 10w50, but he ordered 15w40. I'm going to Watkins Glen tomorrow and I'm changing the oil tonight. Should I use the 15w40, or just use the mobil 1 5w30?. I had mobil1 5w30 in the car last month at wgi and saw oil temps of 305, I'm hoping to keep it a little lower with the 15w40.
...I had mobil1 5w30 in the car last month at wgi and saw oil temps of 305, I'm hoping to keep it a little lower with the 15w40.
305!?! I just bought my car and haven't tracked it yet, but that sounds ridiculously high! Do you have an external cooler? If not, I would probably put one in...
I can't really comment on your original question though... I have a hot-rod of sorts and I have higher oil pressure and lower oil temp with 20w50 racing oil than 10w40 conventional oil. If I were tracking my car, I'd probably put a heavier oil in it. Makes sense to me - Bruce
I run Mobil 5w40 for HPDE events and found it superior to 5w30 during the summer while on the track. Personally, I think a w50 would be too thick. While I have no experience running 15w40; I would think that would be fine.
I don't know how much the effect will be, but I would think the higher viscosity oil will have an even higher temperature because of greater drag.
I think an oil cooler should be in your near future.
