need headlight help
Old Sep 17, 2006 | 02:44 PM
countach_lambo's Avatar
countach_lambo
5th Gear
Default need headlight help
I have a 2000 C5 when I turn my headlights off the drive side goes up and down about 5 times before it stops in the open position
Old Sep 18, 2006 | 12:24 AM
JC in XTC5's Avatar
JC in XTC5
it sounds like both of the plastic stops in the headlight door linkage may be gone.
Here's a TSB on the issue that is likely your problem:
http://corvetteactioncenter.com/kb/q....php?qstId=217
When the plastic stop breaks or is missing, the motor arm has nothing to hit when closing so the motor will continue to run resulting in the door reopening usually until it hits the OPEN stop. But since yours still continues it's possible the OPEN stop is also missing causing the door to continue again until the control module times out.
It's a cheap and easy fix. All you need to do is remove the black bezel surround around the headlight to get to the plastic stops.
Old Sep 24, 2006 | 01:49 PM
countach_lambo
5th Gear
Thank you JC
Thats what it was the two plastic stop tabs were wore out
Old Sep 24, 2006 | 03:18 PM
fej's Avatar
fej
There is a TSB that adds a couple of washers to the drivers side (only) headlight motor assembly to give it a better contact area against the stops. Should help keep them from wearing out.
Also a side note but I had my headlight cage and lens out and left the motor hooked up .. was SCARY how long the motor sees voltage AFTER the headlight is up or down ... poorly designed .. would say that the motor is spinning against the stops (or attempting to) for a solid 1.5 seconds after the headlight has "stopped".
No wonder we all have such problems with gears or stops wearing out ....
Fej
To need headlight help
