Do I have an electrical problem?...
Old Sep 17, 2006 | 03:16 PM
sseladones's Avatar
sseladones
8th Gear
Default Do I have an electrical problem?...
Just bought a 2001 Corvette and the turn signals stop working, the hazard lights....
dealer cant find problem, can anyone help?
Old Sep 17, 2006 | 03:25 PM
dpd's Avatar
dpd
fuse? hazard switch?
Old Sep 17, 2006 | 03:29 PM
patton's Avatar
patton
St. Jude Donor '09
try pushing the 4 ways in and out a few times. or key on turn sig on move the 4 way button around and see it sigs work. 4 way switch is the most common fault. ive been moving mine when they dont work for years i dont feel like doing all the work to fix it
Old Dec 11, 2006 | 09:22 PM
lougars's Avatar
lougars
Default have same problem
Have same problem, what was your solution?
Old Dec 11, 2006 | 10:04 PM
corvettedoug's Avatar
corvettedoug
Just press in the button several times and then try again. Do a search on the forum and there will be directions and pictures on how to change hazard switch/relay.
Old Dec 11, 2006 | 11:46 PM
ZO6TREV's Avatar
ZO6TREV
It is the Hazard switch located right behind the hazard button. i just replaced it in my 2001 zo6. it gets very fustrating when u are in traffic pounding on the dash and pressing in the hazard button several times. i got the switch for 24.00 with my discount which was 25% off from the dealer. there is in easy way to doing this without taking the dashboard apart. you will have to remove the console front bezel temperature unti and pull the radio out there is a great write up on the zo6vette.com website pm for any questions.
Trevor
Old Dec 11, 2006 | 11:47 PM
JC in XTC5's Avatar
JC in XTC5
Hazard switch is common to the hazards, turn signal and brake light circuit, and is known to go bad. Likely the switch is the problem.
Old Dec 12, 2006 | 09:58 AM
lougars's Avatar
lougars
Default Hazard/ switch relay
I'l try this and hope this will provide a solution. Because I have no R/L directional indicators it all runs through the haz switch.
Thank you
To Do I have an electrical problem?...
