well my brother noticed that i dont have the number on my heads (i think it should say 246) but they are polished where it would say my number. This car was modded from what i beleive (racing clutch). Is their a way i can look to see who makes them? sorry i dont have a pic.
I think it's on the deck of the head, but i'm not positive on that.
it is. mine (243) = ls6 heads. my brothers casting number was milled off the heads but there is no name brand on the face of them. i could just pull the valvecovers but that means doing work on a car that is missing everything from the crank back thats out for replacement/repair. the car was modded and demodded by the previous owner. clutch, cut rad shroud(honker or something else), stereo, alarm... the deeper i dig into the car the more stuff i find.
One other way to identify a real LS6 #243 head, is that below the exhaust outlets where the spark plugs are, there are a series of triangles along the bottom cast into the head. Without these you actually have a "sand casted" head. The LS6 heads are a SPM "semi permament mold". The SPM heads will result in 6-10 additional horsepower over the sand casted heads.
D shaped exhaust ports are another feature of a ls6 head. Hard to tell if they are installed with the exhaust manifolds on though
I have a set of AFR 205 heads milled to 58 cc with Comp 921 dual springs and titanium retainers. C/R was around 11.8. They have about 3,000 street miles on them. A small piece of my top ring broke and put reeeeeeally small marks on one cylinder. Mill them another .002 and they will be perfect.
I ended up building a forged 402 with 225 heads.
The cost me 2700.00
Someone make me an offer that is reasonable and I will let them go
I ran them for 4 months and had no detonation or knock. If your tuner is good with Ls1 Edit you can tune the knock right out. Higher C/R is better if you run a big cam. 242/246 618/624 111. You could a slighty thicker head gasket than the .040 cometic I used to get 11.8
100 octane will do nothing for you just burn up your o2 sensors and fry your cats. LG motorsports is shipping 58 CC heads everyday. For a 346 cube motor there fine. If you go up in cubes you have to have more cc due to your C/R will be alot higher. I am running a 402 with -2 cc pistons and a .040 gasket, 225 heads milled to 67cc giving me around 11.9. again I have no knock or detonation. Just tune the timing or adjust the fuel tables to get rid of any issues.
