Active handling problem
Old Sep 18, 2006 | 12:34 AM
Yell6speed's Avatar
Yell6speed
Default Active handling problem
Any body have an idea why my active handling constantly keeps saying on the dash active handling warming up
The active handling light won't turn off in any mode.
Old Sep 18, 2006 | 01:31 AM
MJD's Avatar
MJD
This is normal when you're under 10 mph. Does it kick off when you get above that and say warm up complete?
Old Sep 18, 2006 | 08:51 AM
Yell6speed's Avatar
Yell6speed
Default Stays on all the time
It says active handling warming up at any speed. It does it all day long
Old Sep 18, 2006 | 10:26 AM
MJD's Avatar
MJD
Have you checked for codes?
Old Sep 18, 2006 | 04:15 PM
JC in XTC5's Avatar
JC in XTC5
Check for DIC codes. The most common cause for this erroneous message is that your IAT sensor is the source of the problem.
During initial startup, the EBCM has to calibrate active handling by verifying wheel speed for all four wheels in a straight line. During very cold days, this could take longer and the system is designed to determine outside temperature using the IAT sensor.
However if the sensor, or more likely the connector to it has a problem the EBCM gets an erroneous cold reading from the IAT circuit and displays the message. The DIC codes will confirm if that's the problem, and if it is there's a lot of info on the forum to troubleshoot the connector to verify whether one of the wires in the connector is open. This is common because the wires are very thin.
To Active handling problem
