headlight making grinding sound
Old Sep 18, 2006 | 08:41 PM
sirsenna's Avatar
sirsenna
Default headlight making grinding sound
My pass side headlight makes a weird grinding sound when I shut my lights off, kinda like grinding gears. It actually got stuck tonight & only one headlight opened.
I tried it again & both lights popped up, but still the right one grinded when it came down
any ideas?
Denis
Old Sep 18, 2006 | 10:05 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
yep your motor gear is bad. do a search on headlight motor gears and there are some good posts about an easy fix.
Old Sep 18, 2006 | 11:06 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
http://www.rodneydickman.com/corvette.html
I just did mine, you can't go wrong.
Old Sep 18, 2006 | 11:17 PM
double-oh-coupe's Avatar
double-oh-coupe
Yep, a relatively easy fix ... took me about two hours total (not including the dry-time for the JB Cold Weld!).
Old Sep 19, 2006 | 04:41 PM
JC in XTC5's Avatar
JC in XTC5
Easy fix. Seems to be an epidemic lately. I just did mine 2 weeks ago.
Old Sep 21, 2006 | 12:51 PM
sirsenna's Avatar
sirsenna
can I replace just the gear?
are these the same for all C5s? mine's an 02
Old Sep 21, 2006 | 07:05 PM
'VETTE PHASE
They are all the same, sort of. The '97 - early '00 have aluminum motor housings. Late '00 to '04 have a plastic housing. So, yours is the plastic housing, as is mine. Just order the kit or kits for the plastic housing and it comes with epoxy to glue it back together and if you get them from Rodney Dickman, they come with a brace to help keep the plastic housing from coming back apart. These should last the life of the car as they are brass gears, not the cheap plastic gears that come with it.
Old Sep 21, 2006 | 07:09 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
http://forums.corvetteforum.com/show...589&forum_id=1
Old Sep 22, 2006 | 02:52 PM
alamobiker's Avatar
alamobiker
Remove the head light linkage from the actuator motor then turn the motor in the up direction 180 degrees. That will move the stop postion of the gear and should work.
The motor only uses 60 to 70 % of the gear. That worked for me and the job took about 20min. Good Luck
Old Sep 22, 2006 | 04:45 PM
'VETTE PHASE
This is a good suggestion, especially if it hasn't been doing it very long and not a lot of damage done to the gear. Mine did it for a while, and I put it off until the other one started doing it. I tried to do the 180 rotation deal and it just made the grinding noise when it went up instead of down. Had to break down and get the gears.
To headlight making grinding sound
