Ignition Key Question
Old Sep 17, 2006 | 09:04 PM
robertp's Avatar
robertp
Default Ignition Key Question
1999 C5-
I saw ignition key blanks being sold on ebay a little while back. My question is... how can I determine the resistance of my key. Can I check it with an OHM meter? Do I have to go to a dealer to purchase spare keys or do I have other options. I received only one key when I purchased the Vette and would like to have a couple of spares.
Also desperately need advise with my earlier post
U1255 code and more PEASE HELP!
Old Sep 17, 2006 | 09:16 PM
zozmanZ06's Avatar
zozmanZ06
Default That's Vats!!
On your Corvette key, use a voltmeter to check the chip resistance to 20 K OHMS. Take each lead and place it on each side of the " chip " on your key. A number will appear. Take that number on your voltmeter and apply it to the OHMS chart below. Keep in mind that it may not be exact. Just pick the closest value to your reading. This chart is for any GM product 1997-2004 that has a single or double-sided Vats key. Buy the blank that looks like your key and have it cut at a locksmith shop, hardware store or other fine place that knows what they're doing. I bought my blank on ebay for $15 and it cost $1 to cut it.
VATS # k OHMS
1———— 0.402
2———— 0.523
3———— 0.681
4————-0.887
5————-1.130
6————-1.470
7————-1.870
8————-2.370
9————-3.010
10————3.740
11————4.750
12————6.040
13————7.500
14————9.530
15————11.801
Randy
Old Sep 18, 2006 | 09:07 AM
robertp's Avatar
robertp
Thank you Randy. Great help!
Robert
Old Sep 18, 2006 | 10:55 AM
bighank's Avatar
bighank
Default ignition key
You need a double sided VATS using the values above in the last post
I bought one from locksmithsource. Has other keys too like PATS keys for Ford products. Use VATS in search.
Old Sep 18, 2006 | 08:47 PM
robertp's Avatar
robertp
Thanks bighank. My VAts ohm'd out @ 11.75 ohms so I ordered a #15 key from locksmithsource tonight. I hope it works.
Thanks again
Old Sep 22, 2006 | 01:50 PM
bighank's Avatar
bighank
Default VATS key
Just had my VATS key cut. Works fine but GO TO A LOCKSMITH NOT HOME DEPOT. Called a few and found one that cut both sides for$2.00.
Actually he cut the WRONG KEY first and then tried to re cut it. It ALMOST WORKED (doors only but not ignition) He cut another key (his own blank) and still charged only $2.00.
BTW also ordered a PATS key from Locksmithsource for my son's Mustang. The PATS key has to be programmed to be recognized by the car. Took about 3 minutes to do. Your VATS key with the chip needs NO PROGRAMMING. Just the right resistor value in the key and the correct cut. Good Luck and save about $50 or $100 from the DEALER PRICE.
Old Sep 22, 2006 | 02:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cool Chart!!
BC
Old Sep 22, 2006 | 05:08 PM
robertp's Avatar
robertp
Key blank came in todays mail. I'm gonna try find a place to have it cut this weekend. Locksmithsource sent it right out. Good service!
To Ignition Key Question
