I have a 1999 C5 with 16,000 miles. It has a 6 speed manual transmission that, as of recently, will not grab 6th gear. I am able to "fake it out" occassionally by shifting to 4th and back over to 6th. When it does go into 6th, it stays in without any noise or additional problems.
Has anyone ever experienced a similar issue and what was the cause / resolution? Also, does anyone know a reliable transmission guy in the Chicagoland area that would be able to accurately diagnose and repair without taking me to the cleaners??
Do you have a stock shifter? This can happen if the shifter is not aligned correctly. Also, if you rev the engine up with the clutch in and let the rpm's drop to the same speed as the tranny does it move in to 6th? If you can shift it in to 6th while matching the revs you could have a bad synchro.
