LS2 TB IAC not working
Old Sep 18, 2006 | 10:31 PM
SCannon's Avatar
SCannon
Default LS2 TB IAC not working
I have a 01 C5 With a 402, LS2 TB and a Adapter Harness. My IAC is not moving from 149 where it is set. I put a stock GTO TB on it and it still didnt move. Is there a chance that the wires on the adapter harness are pinned incorrectly?
Old Sep 18, 2006 | 10:49 PM
mfrejek's Avatar
mfrejek
do you have a service manual and a multimeter?
by the way, I know what a IAT and TAC are, what is an IAC?
Old Sep 18, 2006 | 11:01 PM
SCannon's Avatar
SCannon
I believe Intake Air Control
zo6vetteman2003's Avatar
zo6vetteman2003
The plugs on the adapter harness only connect one way. You may have bent a pin, I would check that first.
Are you tuning, or tuned using LS1edit, EFIlive or HPTuners?
Old Sep 19, 2006 | 08:05 AM
see5's Avatar
see5
I have heard of this being the case. Send me an email and I will send you the wiring instructions. With that and meter you should be able to figure it out.
Old Sep 19, 2006 | 05:20 PM
SCannon's Avatar
SCannon
vette@hotrodz.org
I read that I am sopposed to take the 2 wires that dont get used and tie them in with 2 wires that do get used?
Old Sep 19, 2006 | 09:19 PM
RoadRebel's Avatar
RoadRebel
There is no such thing as an IAC on a driveby wire (ETC) throttlebody.
Only Cable drivin TBS have and IAC
Phil
Old Sep 19, 2006 | 09:21 PM
see5's Avatar
see5
I think he means TPS.
Old Sep 19, 2006 | 10:23 PM
SCannon's Avatar
SCannon
Phil
In the tuning why do people set the IAC steps to 149 instead of 310? Does the motor control the IAC with the throttle plate?
Old Sep 19, 2006 | 10:50 PM
zo6vetteman2003
vette@hotrodz.org
This sounds like the 2 white wires on the existing plug. I can give you the pin # and wiring order by wire color.
Old Sep 20, 2006 | 05:35 PM
SCannon's Avatar
SCannon
Can someone clarify how the pcm controls the Idle air control.
Old Sep 21, 2006 | 07:20 AM
zo6vetteman2003
It is a setting within the PCM. I asked earlier if you had tuning. LS1edit, EFIlive or HP tuners can open the throttle position at idle. The wiring harness is a plug in play.
Old Sep 21, 2006 | 05:47 PM
SCannon's Avatar
SCannon
The Harness must not be a plug and play deal if everyone on here and multiple illustrations show the Green and Yellow wire being tied together and the purple and white being tied together. The other end of the plug and play harness does not use the yellow and the white? Am I not supposed to tie these wires together before the plug in harness?
Old Sep 21, 2006 | 06:37 PM
see5's Avatar
see5
There are two sets of - and +5 reference voltage wires so the [Green & Yellow] and [Purple & White] are the same thus you can combine them or not.
Old Sep 21, 2006 | 09:25 PM
SCannon's Avatar
SCannon
Now it makes sense, in all the posts about this I have not seen anyone mention this. Thanks for the info.
Old Sep 22, 2006 | 09:15 PM
zo6vetteman2003
On my adapter harness the two white wires from the existing side are not used. All other colors match up. On the other plug, yellow to yellow brown to brown.
To LS2 TB IAC not working
