Got around to doing some head flow testing this weekend. Shown below is a mildly ported LS1 head, an LS1, LS6, and LS2 Intake. The head was mounted to a 3.9" bore adapter, and all flows were performed at 28" of water:
LS1 head w/ 2.02 Intake Valve, Stock Exhaust Valve
Notice how the port stalls over .500" lift. This is due to the port design and short side radius not allowing the air to turn the corner. The air windows across the valve and the energy is translated into swirl.
The LS6 head offers a better short side radius and higher lift flow capability. Interesting to note that the LS6 Manifold outflows the LS2 intake at the upper end.
Hopefully I will be testing an AFR 205 Head with these manifolds soon.
Enjoy!
Paul
All ports remained open on all intakes. I was looking at the LS2 intake ports and noticed that they seemed narrow with some parting line flash and steps. This intake is made differently than the LS1,and LS6 Intake. My next step is to widen and smooth the LS2 intake ports then re-test.
This is just a hobby that I have been playing around with for the last 30 years. Started out with Lawnmowers, building my own overhead valve head, grinding my own cams, etc, then progressed to cars in the late 70's/early 80's. I bought the flowbench about 5 years ago to learn more about airflow. It has been an eye opener to say the least!
I also restore old Musclecars and currently have an original 69 Camaro SS L-78 and 1970 Z-28 LT-1. Between these hobbies, I stay pretty busy.
L-78 w/Original Paint
70 Z-28
Paul
Paul
The LS6 head was knows to flow better then the LS2 head. Thanks for reconferming this.
If any forum members would like to donate an AFR 205 or 225 head for testing, I would be glad to do a comparison with the above test using the same manifold combination. For a valid test, I would prefer to use the 3.9" bore adapter to keep all tests on an even level. Is the AFR 225 compatible with a stock bore LS1/LS6?
