Old Sep 19, 2006 | 04:06 PM
cazvette's Avatar
cazvette
Default 295 45 18
Any one ever run 295 45 18 in the rear of a C5 vette. I know its not very low profile and should be 295 35 18 , but will this configuration work or has it worked before?
Old Sep 19, 2006 | 05:27 PM
PolishDude's Avatar
PolishDude
just a question, but why?
it will look stupid
Old Sep 19, 2006 | 11:18 PM
99 vett babycar's Avatar
99 vett babycar
it will look stupid
maybe to you - that's not what he asked.
Old Sep 20, 2006 | 12:25 AM
striper's Avatar
striper
I have never seen a 295/45-18 offered by anyone. Who even makes one?
Old Sep 20, 2006 | 12:45 AM
rws.1's Avatar
rws.1
some auto-X drivers run 18 inch front wheels in very low profile to help turn in and 17 inch high profile rear tires to promote forward bite.
Old Sep 20, 2006 | 01:52 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Possible ABS and TCS problems...
I don't know what tires sizes you have now, but if you deviate significantly from the stock rear to front tire diameter ratio, your ABS may think that your front or rear wheels are sliding when you moderately apply the brakes.
Same thing with Traction Control System but you can shut that off.
Roy
Old Sep 20, 2006 | 09:12 AM
cazvette's Avatar
cazvette
Thanks for the opinions , just a breif thought but I diffinantly do not want to jepordize ABS or traction control. Thanks for the input. IF anyone has a 45 series in the rear please attach a pic.
Old Sep 20, 2006 | 11:28 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
It's a GY Eagle F1 GS and it's 28.4" in O.A. Diameter. That gives you a 10% larger tire circumferance and will in effect reduce the number of engine revelutions per mile. Similar to going from a 3.42 to a 3.15 rear ratio. Shouldn't be any ABS problems.
Old Sep 20, 2006 | 09:16 PM
MUKAK's Avatar
MUKAK
those tires belong on a FORD LIGHTNING, some other forum member tried them on his c5 and said they were rubbing inside
To 295 45 18
