C5 Sun visors - mirrors falling out
Old Sep 20, 2006 | 03:48 PM
btraer's Avatar
btraer
Default C5 Sun visors - mirrors falling out
Both of the darn sunvisors on my 2001 C5 fell apart at the same time. The lighted mirrors are apparently held on to the visor by little pieces of plastic that clearly aren't built to last.
They don't look like they can be fixed where they will last for any time so I'm going to order new ones.
How do you take the old ones out without damaging something???
Old Sep 20, 2006 | 04:16 PM
Rhode Warrior's Avatar
Rhode Warrior
Let me know, I broke mine removing them.
Old Sep 20, 2006 | 04:20 PM
hotwheels57's Avatar
hotwheels57
...someone posted the same problem a few weeks ago...you might find the discussion in search (try keyword visor mirror?). There were several suggestions offered to secure the mirror(s) again. How about some construction adhesive in a sparing amount?
Old Sep 20, 2006 | 04:33 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Do a search, someone fixed them some electrical ties.
Old Sep 20, 2006 | 09:05 PM
double-oh-coupe's Avatar
double-oh-coupe
Here is one solution ...
http://forums.corvetteforum.com/show....php?t=1494368
Old Sep 22, 2006 | 08:52 PM
berryj's Avatar
berryj
If u end up buying new visors, Fred Beans is the cheapest. There are instructions on how to install/remove these on the forum as well.
Old Sep 28, 2006 | 04:31 PM
alan3403's Avatar
alan3403
Default Vanity mirrors
The zip tie method works, just repaired mine
Old Sep 29, 2006 | 04:10 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I just removed both of mine and took them to be recovered. I installed the Homelink in the drivers side. Both mirrors are okay.
If you want to remove the sunvisors you will need a stout, small-tipped common (flat blade) screwdriver. Look at the area where the sunvisor mounts near the A-pillar. You will notice a "tab" of sorts. Place the screw driver in the tab and push up. You may want to wrap the sunvisor arm where it makes the 90 degree turn with some electrical tape or something to help prevent scratches. Swing the sunvisor outwards (away from the interior) and this will unlock the collar holding the sunvisor. The electrical connection is a bit of a pain to fish out of the hole, but it will come out without being aggressive.
Here is the thread where I added Homelink.
It has a picture of the "tab" on the sunvisor collar.
http://forums.corvetteforum.com/show....php?t=1510410
Best of luck.
To C5 Sun visors - mirrors falling out
