DRL/Park lamps
Old Sep 20, 2006 | 08:29 PM
wyndzer's Avatar
wyndzer
Default DRL/Park lamps
I have the fuse out so that the DRL's do not come on.(this has worked for a long time) In the lat couple of days my park lamps come on when the key is turned to on,( only the fronts) when I turn the headlamps on the park lamps dim. What should I check to fix this? BCM issue? Ground?
Old Sep 24, 2006 | 02:31 PM
wyndzer's Avatar
wyndzer
Thanks!!!
