Disabling the DRLs
Old Sep 13, 2001 | 03:01 PM
Mark S.'s Avatar
Mark S.
Default Disabling the DRLs
I know that I've seen other postings concerning this, but what is the easiest way to turn off the DRLs. I understand there is a fuse that can be pulled (which one and where is it located). Also, does pulling that fuse cause other lamps not to work, DIC warning, turn signal INOP, etc.?
I just can't imagine having to through all kinds of work to replace this bulbs and since they're on most of the time, a lot of C5 owners will be replacing these a lot sooner than expected.
Old Sep 13, 2001 | 04:45 PM
MDT's Avatar
MDT
Default Re: Disabling the DRLs (Mark S.)
Mark S.,
I pulled #2 underhood fuse.
Good luck.
Mark
Old Sep 13, 2001 | 04:56 PM
Mark S.'s Avatar
Mark S.
Default Re: Disabling the DRLs (MDT)
Mark (MDT), any "ill" effects like DIC messages or other lights not working?
Old Sep 13, 2001 | 05:04 PM
RedLandRocket's Avatar
RedLandRocket
I think fuse #2 are the approach lights which means that maybe the lights won't come on at night when you hit the unlock.
The only way I have discovered is to pull the two relays in the Instrument Panel Electrical Center (#38 and #40), remove the relays from the panel, remove the covers of the relays, insert some type of thin, non-conconductive material between the common and normally open points and then replace the cover and relays.
Old Sep 13, 2001 | 06:23 PM
mozin's Avatar
mozin
You might want to reconsider disabling the DRLs. I pulled the fuse and took the car on a long trip only to return and decide to replace the fuse.
I felt that without the DRLs other cars could simply not see me as well as I wanted and I did not want to turn on my headlights for tunnels and other areas where the signs said to turn on lights. Another reason is that I tend to exit the car and head to the back of the car and then hit the remote lock button. The white rear lights at the license plate are also disabled when the fuse is pulled. This was an inconvenience I chose not to continue so I put the fuse back in place. :nopity
Tom
Old Sep 13, 2001 | 11:22 PM
bparker's Avatar
bparker
You can do what I do, just turn on your fog lights (as the DRLs turn off). They are not as noticable - but still get the eye of someone if you are passing them in the side mirror ..
BP
[Modified by bparker, 9:22 PM 9/13/2001]
Old Sep 13, 2001 | 11:37 PM
RACER-X-C5's Avatar
RACER-X-C5
isnt there an option on the DIC controlls to turn off the lamps. i thought i read that in my owners manual.
Old Sep 13, 2001 | 11:44 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Disabling the DRLs (RACER-X-C5)
unfortunately not for the DRLs...only way is to pull #2 fuse, as mentioned or diable the #38 and #40 relays, don't qoute me on the relay #s....
Mark
Old Sep 14, 2001 | 01:07 AM
MDT's Avatar
MDT
Mark S.,
As RedLandRocket mentioned, the approach lights are disabled....other than that, it stores several codes, but does NOT set a check engine light. I've forgotten just which codes are involved. I'm perfectly happy with the results of removing the #2 fuse.
Good luck.
Mark
Old Sep 14, 2001 | 12:25 PM
Mark S.'s Avatar
Mark S.
Default Re: Disabling the DRLs (Mean Green 2000)
Mean Green, any "ill" effects such as annoying DIC messages, or other lamps that won't work if I pull fuse #2?
To Disabling the DRLs
