Cutting the front bushings....?
Old Sep 20, 2006 | 11:10 PM
RickC5's Avatar
RickC5
Default Cutting the front bushings....?
How exactly do you do this?
I have searched but have not found any answers......
My car is currently lowered as far as it will go in the front with the bushings still in theyre original shape, id like more of a drop.
Do you have to take the bolt out and then the bushing comes out or what?
And what do you recommend to cut it with?
Old Sep 20, 2006 | 11:17 PM
Jeffs FRC's Avatar
Jeffs FRC
Remove the bolt and you'll understand what to do.
I used a palm grinder with a cutoff wheel. My buddy used a hacksaw.
Old Sep 21, 2006 | 12:05 AM
DngrZne's Avatar
DngrZne
I used a hacksaw too, but I recommend not cutting it while holding it in your hand...ouch...
Old Sep 21, 2006 | 07:17 AM
BlueThunder2000's Avatar
BlueThunder2000
Vettaholic
When I did this, I could not get enough suspension travel downwards to remove the bolt, so I had to remove the lower ball joint. This is not difficult, but to get the joint separator tool in, I had to unbolt the steering linkage so I could rotate the entire spindle and get enough clearance for the tool.
I cut the rubber about half way. Noticeable drop. But now I consider to remove the bolts altogether.
Good luck, I think this mod is worth the effort
Old Sep 21, 2006 | 08:18 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
This is the procedure I used except I didn't remove the bushing instead I seperated the lower ball joint and while holding the lower A-arm clear I cut 1 segmant off of the bushing.
https://www.corvetteforum.com/techti...D=90&TopicID=1
Old Sep 21, 2006 | 09:31 PM
FKING1's Avatar
FKING1
I cut 2/3 off mine with a Sawzall. Left the bolt in its original position, did not remove it. Worked fine.
Fred
To Cutting the front bushings....?
