6-speed guys inside Poll
Old Sep 27, 2006 | 12:38 PM
  #61
02gt350's Avatar
02gt350
I have the new B&M that can go in a C6 or C5. It has a noise isolator to keep rattles down. It makes no noise at all and the feel is great. It has great response and makes the stock feel liek a sloppy loose stick in the mudd
Old Sep 27, 2006 | 02:08 PM
  #62
VetteDrmr's Avatar
VetteDrmr
I just shortened my stock shifter via Chuckster's instructions. Gets rid of the rubber isolator, shortens the throw about an inch (you can go more, but that's what I wanted), not notchy and doesn't rattle.
Oh, and the cost??? Priceless.
HTH, and have a good one,
Mike
Old Sep 27, 2006 | 03:44 PM
  #63
cjs27410's Avatar
cjs27410
BPP shifter here. Will never go back to stock.
Old Oct 5, 2006 | 10:40 PM
  #64
Brad@RevXtremeAutoSports's Avatar
Originally Posted by muncie21
I'm running a Kirban. Definately an improvement of the stock shifter.
delrin **** too
Old Oct 5, 2006 | 10:49 PM
  #65
Tx Ray-C5's Avatar
Tx Ray-C5
Personally, I purchased a Hurst, had it in the car for about a month, took it out and sold it ! It was to stiff and notchy for me. As of now I'm looking to get a Ripper.
Just my .02
Old Oct 6, 2006 | 11:24 AM
  #66
MJD's Avatar
MJD
I'm a tall guy and with the seat all the way back it feels like I have to reach for the stock shifter. The adjustability of the BPP makes it very nice and much more comfortable.
Old Oct 6, 2006 | 08:59 PM
  #67
Greg_E's Avatar
Greg_E
Mike
I did something similar to Chucksters mod, and we installed it in my buddies car. It's a big improvement over stock, and cost next to nothing. I will say that taking the shifter apart, is not the easiest task, but if you have more time than money, give it a try. If you don't like it, go spend the money on an aftermarket shifter. I don't have a welder, so I removed 1" from the outer shell with a cutoff wheel , removed all the rubber (a heat gun will help here). I then cut a small amount from the end of the shift rod, in order to get the full 1" shorter length. I then filled the void where the rubber was, with a good quality epoxy putty and then drilled and pinned the two pieces together just to insure nothing could come apart. Use a good epoxy like Marinetex (this stuff is just about bulletproof) or PC7 (light weight but strong) which is what I used. I think you'll like the results.
Old Oct 6, 2006 | 09:51 PM
  #68
KorbenDallas's Avatar
KorbenDallas
I shortened the stock shifter using the tap-die method. It shifts super-easy, but some people who've driven my car notice that it wasn't as precise as aftermarket ones.
If I were to replace it, I'd go with a C6Z06 shifter.
Old Oct 7, 2006 | 08:29 AM
  #69
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I had the B & M. The first week I was ready to take it out it was so stiff. After a couple of weeks it loosened up. It is now the nicest shifter I have found. I have driven other cars with the Hurst and BPP's and was told theirs was stiff and took a little break in time as well. My preference, all things considered was the B & M. Back when I was ready to install a shifter LPE reccomended the B & M and informed me it would take a little while to break it in.
Old Oct 7, 2006 | 09:26 AM
  #70
Sundevil's Avatar
Sundevil
Dang, the only prob I had with the stock shifter was I couldn't cleanly see all the climate controls! Took the stock one out, used a ban saw to cut off 7/8" of the 1.5" of threading, installed a Flameball and was good to go. The stock shifter feels great rowing through the gears...especially an inch shorter. Just an alternate solution to consider.
Old Oct 7, 2006 | 11:23 AM
  #71
Sorny's Avatar
Sorny
I've got a Hurst, and after a few months of break-in, it is the only way to go (it loosened up a bit after about 3000 miles of use, that was 2 years ago). I had forgotten how crazy-short the throws are, until I drove my brother-in-law's stock Z06. While the stock shifter is adequate for a normal car, a sports car should have a shifter that is not vague in feel, nor overly long in throw.
Ditch the POS stocker and get an aftermarket shifter! I'm partial to my Hurst, but there are several options; try to drive cars with different shifters to get a feel for them.
Things I notice about the Hurst:
* Increased effort? Yes, no question about it (breaks in nicely with the stock springs, IMHO).
* Rattle? Not very much after I put a nice MOMO **** on it (stock **** rattled like a ****).
* Shorter throw? Hell yes, about 1.5 inches from gate to gate, if that.
* Missed 3rd gear? Never.
The last point is the reason I bought the shifter. After missing 3rd at 70MPH, and the resulting sideways action, I decided the stock POS shifter had to go. There is no denying the faster shifts, and no mistaking what gear you are in with a Hurst.
Sorny
Old Oct 7, 2006 | 11:46 AM
  #72
Quasar Z's Avatar
Quasar Z
Why did you go sideways at 70 mph when you missed third gear?
Old Oct 7, 2006 | 11:50 AM
  #73
Sorny's Avatar
Sorny
First gear at 70 is a bad thing.
Sorny
Old Oct 7, 2006 | 01:12 PM
  #74
msghuff's Avatar
msghuff
Originally Posted by PVHolgado
I have a shortened stock stick no problems and it shifts smoooooth-
Me too!
Old Oct 8, 2006 | 04:48 AM
  #75
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
b&M here love it, i had the bpp sucker fell apart on me ,and it was a piece of crap from the get go.
Old Oct 8, 2006 | 10:25 AM
  #76
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Default MTI 6 Shooter
Reading your comments about the MTI 6 shooter.... I'ts now in the front for my Xmas list
Originally Posted by gorillavet
Go for it! It's an aftermarket shifter with very short throws that feels like stock! It's the best of both worlds
Originally Posted by Honez
Let me just say that I have tried them all and none of them match the one that the guys from MTI Racing have http://www.mtiracing.com/artmaverick...uctspage2.html
Thanks Quasar... this is the comment I was waiting to hear (comparing MTI to stock, and Hurst....)
In the past three weeks I have had a stock shifter, Hurst shifter and now an MTI shifter in my Z06. The MTI is the hands down winner and the shifter that will remain in my car.
Old Oct 8, 2006 | 10:28 AM
  #77
Toque's Avatar
Toque
Default Need some help guys with Factual Shifter Comparo !
Guys:
Please help with this factual comparison of shifters in my post:
http://forums.corvetteforum.com/show....php?t=1518282
I'm really interested to see the throws of the MTI 6shooter, Hurst, and B&N......
Thanks guys !
To 6-speed guys inside Poll
Old Oct 8, 2006 | 01:29 PM
  #78
Kappa's Avatar
Kappa
Touqe, did you read this link? It has a ton of info on the MTI shifter.
FAQ page
Old Oct 8, 2006 | 02:23 PM
  #79
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by Silver SS
What do you have and do you like it?
Hurst plus here. kept oem springs...stiff at first, then it loosens up after 1k miles. It kept loosening up th emore I used it. After 2 years, its just perfect. no issues, im glad i stuck with it. Vette is so much more fun to drive with a short throw.
Old Oct 8, 2006 | 04:01 PM
  #80
Toque's Avatar
Toque
FAQ page
Yea I read it,
Good info, but not like what I'm trying to put together.
Toque
