SS3200 Stall - hesitation / sputtering on launch
Old Sep 22, 2006 | 08:52 AM
94legaleagle's Avatar
94legaleagle
Default SS3200 Stall - hesitation / sputtering on launch
I've got a 2001 coupe w/ Dynatech Suppermaxx LT headers, Yank SS3200 stall converter and an ECS 3.73 rear end - I HAVE had my computer BENCH tuned, but not yet dynoed - After the bench tune, I'm not getting any codes other than an OCCASSIONAL P1133 and P1153 which are rich/lean codes.
It is my understanding that w/ my SS3200 stall converter that I SHOULD be able to apply the brake, rev the engine to 3200 RPM, let off the brake and launch the car
However, when I put on the brake and rev the engine, I can ONLY get the engine to rev to about 1800 RPM - when the engine hits about 1800 RPM, it starts to sputter and seems to loose power
My car seems to run excellent otherwise, and this seems to only be a problem when I try and lauch the car - getting the RPM's past 1800 is NOT a problem during normal driving - I can put my foot into it and it pulls hard when normal driving
Do I simply need a dyno tune to eliminate this launch problem? Or should I be looking for something else?
Thanks for your input.
Old Sep 22, 2006 | 03:53 PM
berryj's Avatar
berryj
You are sputtering because your traction control is on. Turn it off and do the same and it should be fine. I have the same problem at the track even w/ a stock converter. Also, I've been told that u don't need to brake stall, but just mash the pedal and it will flash the converter to 3200 and launch! Hold on and point it in the right direction if u can get traction.
Let me know how this works out for u.
Old Sep 22, 2006 | 04:02 PM
Phil97SVT's Avatar
Phil97SVT
Don't foot brake it. Let the car idle at the light and stab the gas on the 3rd yellow, you will always get better 60's and RTs that way.
Phil
Old Sep 22, 2006 | 05:06 PM
94legaleagle
THANKS, both Berry & Phil (and welcome back Phil, I was pullin' for ya )
I'll try what both of you said, and I'll post here to let you know the results - I'm getting close to my 500 miles on my rear gears, so very soon I can mash the pedal and hold it there -
Actually, it was a used rear end that I installed, so I'm assuming that I really don't need to put 500 miles on it, but I'm trying to error on the caution side for just a little
Old Sep 22, 2006 | 07:43 PM
Face's Avatar
Face
Phil
I've always had the opposite results with the SS4000 I used to have and the YPT4400 I have now. I believe it varies on the converter line. I hear Vig's like to be flashed from a idle.
To SS3200 Stall - hesitation / sputtering on launch
