P 0351 - Ignition Control Circuit # 1
Old Sep 24, 2006 | 11:37 AM
z track's Avatar
z track
Default P 0351 - Ignition Control Circuit # 1
Car is missing cylinder(s) at low rpm, I get this fault code - anyone worked through this or anything P0351- P0358 one for each cylinder?
TI A for any help
Old Sep 24, 2006 | 11:52 AM
patton's Avatar
patton
St. Jude Donor '09
a quick test is find a missing cyl. then swap coils from a good cyl. i dont know what tools ya have . an ignition tester is the ticket. proper testing is 18 different steps
Old Sep 26, 2006 | 05:28 PM
z track's Avatar
z track
I had the same thought and did this, and strangely enough, the problem, and the code went away. There is a series of the sames codes for all the cylinders, and expected to get the similar code for the cylinder i switched to but didn't. I am going to cointinue to monitor it...
To P 0351 - Ignition Control Circuit # 1
