Right side door power window and lock not operating
Old Sep 24, 2006 | 07:08 PM
sts1187's Avatar
sts1187
3rd Gear
Default Right side door power window and lock not operating
When I drove my 99 convertible last week the passenger side window would not go down, this has never happened before. In trouble shooting I found that the power lock only works from the lock button on the passener door. THe auto lock does not work as well. Scaning through the codes on the driver information center I get " no communication " no codes.
Any help would be appreciated.
Old Sep 24, 2006 | 07:29 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
this happened to me.. its the door module cost about 225 bucks easy fix
Old Sep 28, 2006 | 06:04 PM
sts1187's Avatar
sts1187
3rd Gear
Where is a good source to get the module? Is ther a source that repairs and takes the old one as a "core"?
Old Sep 28, 2006 | 07:40 PM
99jimb's Avatar
99jimb
Navigator
I had the same problem , pulled on the boot between the door and it worked again. The ground wire ended up being loose. cheap fix.......jb
To Right side door power window and lock not operating
