Does it help to turn key "On" before starting?
Old Sep 13, 2001 | 11:18 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Does it help to turn key "On" before starting?
Following advice posted here, I have always turned the ignition key to "on", waited for the electronics to stabilize (about 5 seconds), then over to "start". In 18,000 miles I have never had a single electronic problem- no active handling quirks, no goofy codes, no nothing. But now that my Valentine is hardwired, it goes through its test cycle when I turn the ignition to "on", and then again when I start the engine. All that tweeting from the V1 is annoying, and I am now putting two on/off cycles on the V1 every time I start the car, which may eventually shorten its life. How many of you guys with 2001 cars just go right to "start" (without pausing in "on") and are not having problems???
Old Sep 13, 2001 | 11:31 PM
BKVIEW4U's Avatar
BKVIEW4U
Default Re: Does it help to turn key "On" before starting? (Gearhead Jim)
i dont turn the car right to start. i wait about 2 seconds for the fuel pump to fully prime and all the electronics to stabilize as you said. i feel its easier on the fuel and ignition stuff....jmo
Old Sep 13, 2001 | 11:35 PM
97silverbullet's Avatar
97silverbullet
Default Re: Does it help to turn key "On" before starting? (BKVIEW4U)
I always let the guages go through their cycle and let the chime stop, before I start the engine. :chevy
Old Sep 13, 2001 | 11:39 PM
GasmanZR1's Avatar
GasmanZR1
I do the same thing, and I am annoyed by the V1 going through its startup twice as well. The only solution is to either unplug the V1 or turn it off before start and on after starting. I don't know if letting the electronics "do their thing" before starting is actually beneficial or not, but it can't hurt, I don't think.
Michael
Old Sep 13, 2001 | 11:42 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
I still play the gauge dance game
Mark
Old Sep 14, 2001 | 12:26 AM
EHS's Avatar
EHS
I wait until the bells and whistles stop. Also make sure that the radio, etc. are off. I use the idle time to fasten my seatbelt.
Old Sep 14, 2001 | 12:31 AM
jimhild's Avatar
jimhild
Default Re: Does it help to turn key "On" before starting? (EHS)
We just get in turn on the key and start the car. I don't think there is a 1/2 second delay ever.
No issues of anykind!
Either way works in our opinion. 38,000 miles to date.
:D
Old Sep 14, 2001 | 02:27 AM
mozin's Avatar
mozin
I can't believe people are waiting seconds to start their engines just to let the electronics do their thing. Never before heard of such a procedure except for diesel engines. :crazy:
Tom
[Modified by mozin, 10:28 PM 9/13/2001]
Old Sep 14, 2001 | 08:37 AM
SEAMOORE's Avatar
SEAMOORE
I wait till the dic clears after talking w/ Sonny Kilgo after i had a column lock about 15 months ago. He suggested this. So for so good, 15,000 miles since and no problems.
Old Sep 14, 2001 | 08:39 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: Does it help to turn key "On" before starting? (SEAMOORE)
i just let her rip, no waiting for the guages.
Old Sep 14, 2001 | 08:47 AM
stevenll's Avatar
stevenll
Default Re: Does it help to turn key "On" before starting? (2000^C5)
I just start it up. No problems in 11 months and 11,000 miles.
Old Sep 14, 2001 | 08:55 AM
Yellow 01 Coupe's Avatar
Yellow 01 Coupe
Default Re: Does it help to turn key "On" before starting? (stevenll)
I am not the authority on electrical systems or anything, but don't electrons travel at the speed of light? Electrons traveling at the speed of light for 5 seconds would cover a distance of 931,410 miles. I just start the car without waiting for electrons to do anything special.
Old Sep 14, 2001 | 09:36 AM
C5 Tweaker's Avatar
C5 Tweaker
There is no benefit at all to doing this. It is designed to function for immediate start.
Old Sep 14, 2001 | 09:42 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Does it help to turn key "On" before starting? (C5 Tweaker)
I do the same thing. It probably doesn't do any good, but I feel better anyway. I also get the annoying double V1 alert.
Old Sep 14, 2001 | 09:46 AM
RedLandRocket's Avatar
RedLandRocket
So I understand, the system won't fire the starter until it has cleared all of it's check list. I think it checks about 5000 things before it will start. Camshaft position, all piston positions, external temp, coolant temp, IAT, fuel level, transmission selector position, seat position, clutch/brake position, stock market position.
I also understand that you can't engage the starter with the engine running. I haven't been brave enough to try it but it would make sense.
Old Sep 14, 2001 | 09:49 AM
Yellow 01 Coupe
Default Re: Does it help to turn key "On" before starting? (RedLandRocket)
This is definately true. Don't ask how I know :blueangel: I just know.
Old Sep 14, 2001 | 11:05 AM
SAXN8R's Avatar
SAXN8R
Default Re: Does it help to turn key "On" before starting? (Yellow 01 Coupe)
I was too curious about the starter not engaging while the engine was running, so I tried it. It does not spin the starter, but the car goes through a gauge dance of some sort. Maybe it is telling you that you are an idiot for trying to start the car while it is already running. :D
To Does it help to turn key "On" before starting?
Old Sep 14, 2001 | 11:17 AM
Mike Siska's Avatar
Mike Siska
Same here :yesnod: I like to see the gauges do their 'sweep' :D
Old Sep 14, 2001 | 12:34 PM
lotzahp's Avatar
lotzahp
it's just a C5 ritual most of us do......gives us time to pray to the column lock and dead battery gods.
Old Sep 14, 2001 | 02:16 PM
Evil-Twin's Avatar
Evil-Twin
I have to laugh at this... no flame intended.. I was brought up as a child not to answer the telephone on the first ring.... seems weird huh.. I did this for like 20 years.. then one day I asked my mom.. why .. do you wait untill the second ring.. her answer " I dont know" ... funny how some things stick but have no real purpose..
I never wait for all that stuff to crank up... 38,000 miles no problems..
