Went to change my oil filter today and discovered that there was no room to use the swivel handled slip wrench. I guess everyone uses a large socket that fits over end of filter.
The correct filter wrench (size/number of flutes) for C5 oil filters can vary based on the brand/type oil filter you use. One of your local auto store should have an assortment of filter wrenches and you should be able to find the correct filter wrench for the brand/type oil filter you use there.
my swivle wrench works . i get maybe 1 inch travel then regrip and by then hand loose same on tightening hand tight then one or two grips with wrench. ya can by one that takes a 3/8 drive extention
Good luck!
Great .... event the filter wrench size depends on the filter
....................I thought it would be a piece of cake to remove the darn filter !!!!!
Try getting the strap wrench around the filter at an angle. I've never had much (Ok, any) success with filter wrenches. If the filter isn't too tight the strap wrench at an angle works just fine, and if it's too tight for that, the filter can will deform and render the filter "socket" useless anyway.
THEN you want to the previous bozo (even if it's yourself ) that put the filter on too tight!
Good luck!
This is why I went to the K&N HP1007 Oil filter, it has a nut on the bottom of the filter. EZ on and EZ off
HTH, and have a good one,
Mike
I tried but there was something like an inch to work with and the header collectors were in the way.
Maybe somebody with better mechanical abilities would have been able to get it with the strap type I got.
Mike
Strap wrench is the way to go. I have one of those "fluted cans" typeof filter wrench and it keeps slipping or the extended drive portion of the wrench comes out. Maybe I just have a cheap one.
...you should only be tightening it hand tight with the rubber seal lubed, anyway. Fill the new filter with fresh oil so you don't "dry start" the motor.
In a pinch, use the old trick of stabbing a large screw driver through its heart, let it drain, then remove it using the screwdriver as leverage...
Well I did try taking it off by hand only. So I don't know if that means ti was put on too tight or if they tighten up with heat and time.
The screw driver idea sounds easy too. Sure you cant hurt the filter mounting hardward ???
...they will tighten up slightly with heat cycling/time, but most likely someone put it on with an oil filter wrench in the past. Use the screw driver only as a last resort if the correct tool is unavailable. The trick has worked for me about a half dozen times when the correct filter tool either wouldn't fit into the area or slipped off. I have the largest assortment of oil filter tools in the SW by the way. Now I'll need another one for the Z16.
The filter will be trashed of coarse, and stab it closer towards the bottom/middle to avoid the threaded adapter which the filter screws onto.
DH,
I use one of those 3/8" filter adapters too and all I did was buy it at Kragen or Autozone (I don't remember where I bought it) after getting a filter for a Corvette off the shelf and picking the right size adapter. I was told by the sales guy that they have a tendency to break, so I put a zip tie around it to help it stay in one piece. I've been using it for about a year now on my car and my wife's car with no problems. Just snap it onto your 3/8" extension, snap that into a ratcheting driver, and the filter comes off easily, with plenty of room to spare.
