Need Alignment After Engine Swap ???
Old Sep 25, 2006 | 12:57 AM
Dirty Howie's Avatar
Dirty Howie
Default Need Alignment After Engine Swap ???
Just curious...... I'm not sure all that gets removed when pulling an engine.
Do you need to get a new alignment ???
DH
Old Sep 25, 2006 | 07:18 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
In through the top or bottom?
Old Sep 25, 2006 | 04:25 PM
Dirty Howie
Not sure ...... I will ask when I see my tuner tomarrow !!
If thru bottom then ....????
DH
Old Sep 25, 2006 | 04:52 PM
94legaleagle's Avatar
94legaleagle
If out thru bottom, then yes you will need an alignment because your entire front suspension would have to be removed and reinstalled for removing the engine from the bottom.
Old Sep 25, 2006 | 05:13 PM
robvuk's Avatar
robvuk
Also, if the new engine weight was different enough to change the ride height in the front.
Old Sep 25, 2006 | 06:00 PM
Dirty Howie
Interesting point.......do 402's weigh much more than stock 346's ???
DH
Old Sep 25, 2006 | 06:04 PM
robvuk's Avatar
robvuk
DH
I doubt there's much difference in weight but you can check the ride height with another stock car.
Old Sep 25, 2006 | 06:19 PM
Dirty Howie
My car is already pretty low !!!!!!!!
But I'm thinking an alignment is in my near future
DH
To Need Alignment After Engine Swap ???
