New Washers With Diff Fluid Change??
Old Sep 25, 2006 | 04:37 AM
LIGHTNING's Avatar
LIGHTNING
Default New Washers With Diff Fluid Change??
Do you need to install new washers when changing diff or tranny fluid?? Shop Manual mentions washers...but not size or type. I'm assuming crush washers?
Old Sep 25, 2006 | 09:59 PM
vettezeke's Avatar
vettezeke
Default Diff plug washer
I reuse the washer, as long as it is not cut across the sealing surface or kinked. I is a soft metal seal washer which appears to be aluminum. If the faces are smooth it should be no problem.
Old Sep 26, 2006 | 12:34 AM
jbauch357's Avatar
jbauch357
no need for new wahers, just use what is already there. if you want to be really picky get some teflon tape to put on the threads of the drain/fill plugs when you re-install them.
To New Washers With Diff Fluid Change??
