Techron Fuel System Additive....Question
Old Sep 25, 2006 | 10:17 PM
Lowtow's Avatar
Lowtow
You Guys are super smart!
can you tell me how much Blinker Fluid the c5 takes???
Old Sep 25, 2006 | 10:47 PM
ndirishr1's Avatar
ndirishr1
use the 20 and avoid all the sarcasm
Old Sep 25, 2006 | 10:56 PM
NYCHASM's Avatar
NYCHASM
From: Probably talking that police officer out of giving you a summons! ========== The Beautiful Lower Hudson Valley, NY
St. Jude Donor '08-'09
Be careful! This was only standard on the Z06 models and was an option on the verts and coupes. Make sure you have this option or you'll drive yourself crazy looking for the filler neck.
Charlie
Old Sep 25, 2006 | 10:57 PM
NYCHASM's Avatar
NYCHASM
He's right! Sarcasm comes standard with the 12.
Charlie
Old Sep 25, 2006 | 11:03 PM
Jack_leg's Avatar
Jack_leg
Forget it...
Old Sep 26, 2006 | 09:51 AM
DRR's Avatar
DRR
You ever wonder...
How does the car know how much Techron to put in the left tank and how much to put in the right tank?
And do you need to do a few slaom runs to agitate the mixture?
Do you need to use the Fuel System
Treatment first, or the Fuel Injector Cleaner first?
I'm confused.
Sometimes I don't know any more after thinking than before I'd begun...
Old Sep 26, 2006 | 10:00 AM
NYCHASM's Avatar
NYCHASM
Originally Posted by DRR
You ever wonder...
I'm confused.
I would categorize your questions as normal things to be concerned about. If you look carefully around the forum, you'll find many others that think pretty much the same way. It would be nice if you all formed some sort of club...you know, like Mensa or something!
Charlie
Old Sep 26, 2006 | 01:27 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by JD's C5
The most logical post that I have read. Now if we could just get the square root of the hypotenus we would be fine. That would give us the answer down to the closest micro mililiter
I think it's more of the angle of the dangle equalling the heat of the meat which is not to be confused with the torque of the dork.
Old Sep 26, 2006 | 10:19 PM
Lowtow's Avatar
Lowtow
Old Sep 26, 2006 | 10:47 PM
DngrZne's Avatar
DngrZne
But you have to then state if we are referencing parallel or perpendicular to the normal to then know if the angle of the dangle is directly proportional or inversely proportional as well as if it follows a linear relationship with the heat of the meat.
