brake rotor question
Old Sep 26, 2006 | 04:53 PM
Tigershark3's Avatar
Tigershark3
FWIW I got the Brembo rotors that are D/S. Zinc Coated. I like em . Here's the link:
http://cgi.ebay.com/ebaymotors/97-04...spagenameZWDVW
Old Sep 30, 2006 | 11:32 PM
jfman's Avatar
jfman
Originally Posted by bighank
Got REAL GM ROTORS for $22.80 from ac delco supplier. List about $130
Call em and get the real thing for LESS. Use NON-CERAMIC (semi-metallic) if you want to STOP the car. OEM pads great for street use .
$22.80 where ?
Old Oct 3, 2006 | 01:10 PM
bighank's Avatar
bighank
Default AC delco rotors
Local AC Delco distributer TMI in Beltsville, MD. It should be the same at any Delco dealer if you get the right price.
Old Oct 3, 2006 | 03:34 PM
jfman's Avatar
jfman
So this way I would get the same exact part as if I ordered from gmpartsdirect.com ?
Old Oct 3, 2006 | 04:47 PM
BATM4N's Avatar
BATM4N
Old Oct 4, 2006 | 01:49 PM
bighank's Avatar
bighank
Default rotors
Mine is a 98 C5 I'll look up the parts numbers. Since the flutes are directional you need 2 different rotors and don't put them on the wrong wheels or you might just make your C5 into an Autogyro. My rear rotors were a little scored but not much. Most of the braking goes to the front as evident from looking at the caliper size front vs rear... Buy some caliper paint when you do this and you will emulate a Z06.
BIGHANK
