i found company on Ebay that sells Corvette brake rotors. several reviews from non-bias sites suggests that the brakes perform well and are smooth and silent in operation.
here's the link to the ebay store:
my question involves choosing a style of brake rotors offered. as you can see the store offers a number of different drilled/slotted combinations and styles. Is it better to have only drilled/only slotted or some combination of both?
Drilled and slotter are purely for BLING BLING and do not help stopping power at all. Performance rotors dont use drilled or cast in holes. Slots will scrap the brake pad to remove any glazzing material and will also decrease pad life.
solid side rotors for best stopping performance. D&S for
I installed mine for the bling and to cut down the brake dust, but as far as stopping I have to disagree. I installed Baer Eradispeed zinc coated rotors with hawk ceramic pads and there is a BIG difference when I push the pedal. I have 90% less dust and I don't get any noise at all. The key is, buy quality rotors and pads. Go cheap and you get what you pay for...
I installed Baer zinc coated rotors with hawk ceramic pads and there is a BIG difference when I push the pedal. I have 90% less dust and I don't get any noise at all. The key is, buy quality rotors and pads. Go cheap and you get what you pay for...
Sigh....
*ANY* brake rotor will stop fine on the street in normal use. Just like any brake pad will stop fine on the street in normal use. Usually the tires are the limiting factor in braking (assuming you can get the ABS to engage).
You *will* find your brake pads wearing faster with slotted rotors. You also have about the same amount of dust as normal pads, it's just not as visible with ceramic pads.
BUT, if you ever want to take those rotors & pads to the track, be prepared. Go do a search on "rotor crack" on the Autocross/Road Racing forum, you'll see some very educational pictures.
As stated for Street use most people will not notice any issues because their brakes will out perform their tires. That being said there is no one on the track using D/S and/or ceramic pads because that is just asking for trouble.
D/S will crack much faster than solid and ceramic pads do not stop you quicker than OEM Z06 pads and what good is that.
Ceramic pads do dust it is just white instead of black thus it is harder to tell. It is also easier to remove from the wheels then many of the harsher pad compunds.
Best Stopping power for the street IMHO - Solid Rotors with OEM Z06 pads.
Have a good one,
Mike
Yup Mike mentioned one of my HOT buttons.
Drilled and slotted are purely for BLING. Dont get me started on how bad ceramic pads are for stopping a car. up to 5% longer to stop a car with ceramic brake pads under normal conditions. 15% longer under extream or emergancy stopping conditions. Ceramic brake pads can not take the heat of hard stopping. Only to reduce dust for the moderate to normal braking.
Ceramic brake pads have their place in the automotive industry, just not on Pick-up trucks and performance cars.
Bob, thanks for sharing your experience and insight with the forum.
Whatever you do, never settle for the cheaper brand. I got some cross/drilled rotors from E-bay and they warped in 10 days under normal use. Cost about $200 and got cheap parts.
My new brake system are Durastop’s from GM and had them zinc plated for corrosion resistance. I'm also using D/S Z06 pads with great success.
I use the brakes/rotors for show effects only and not for race.
Got REAL GM ROTORS for $22.80 from ac delco supplier. List about $130
Call em and get the real thing for LESS. Use NON-CERAMIC (semi-metallic) if you want to STOP the car. OEM pads great for street use .
