engine stalled twice
Old Sep 25, 2006 | 09:48 PM
gary stanford's Avatar
gary stanford
2nd Gear
Default engine stalled twice
Started 2000 vette twice and stalled both times,a message appeared on display saying to remove key and wait 10 seconds,what gives
Old Sep 25, 2006 | 09:59 PM
chevyvettezr1's Avatar
chevyvettezr1
try your spare key if u have one...my 99 did the same thing so i went and had a key made...solved my problem..the little chip gets worn out thats on the key.
Old Sep 25, 2006 | 10:28 PM
Vassili's Avatar
Vassili
Column Lock - You may be screwed. Search for other threads on the dreaded CLB. Do you have an MN6? usually happens mostly to them. And correct it before it locks on you.
SUPERCRUZ's Avatar
SUPERCRUZ
Sounds like a column lock issue to me. Check to make sure your steering wheel is unlocking when you turn the key. If your wheels are at an angle, take some presure off the wheel and turn the key. You should here the column lock mechanism pin unlock. Of course, this is if you do not already have a CLB installed.
Old Sep 26, 2006 | 02:37 AM
muncie21's Avatar
muncie21
The wait 10-seconds code is related to VATS. The column lock is a separate issue.
To engine stalled twice
