wheel torque specs
Sep 29, 2006 | 05:18 PM
wheel torque specs
I need to re-install my wheels after a caliper paint job. Anyone know the wheel torque specs. Could not find in search. 50th AE
thanks,
DAN<>
Sep 29, 2006 | 05:33 PM
St. Jude Donor '07-'12, '20
100 ft. lbs
Sep 29, 2006 | 06:04 PM
Sep 29, 2006 | 07:35 PM
Make sure that you alternate from side to side when tighting them down . Don't do it sequentially as the wheel will not be flush with the rotor and there for wobble.
Sep 29, 2006 | 07:51 PM
Quote:
Originally Posted by 16Again
100 ft. lbs
It's in the owner's manual also..
Sep 29, 2006 | 09:09 PM
St. Jude Donor '05-'06
100 ft. lbs
I swap rims several times a week
Dave
Sep 30, 2006 | 02:13 AM
The correct procedure is to tighten them in increments of 30, 60, and then 100bs. You are not supposed to go from 0 straight to 100.
Sep 30, 2006 | 02:32 AM
St. Jude Donor '06-'07-'08-'09
after driving it about 50 mles I would re-torque. Break the bolt lose and bring it back to spec one at a time. It's much better than just hitting the bolt with the wrench to spec.
Sep 30, 2006 | 08:10 AM
the spec is a dry thread spec ... that means no lubricant....
