PCM code p1221 Throttle Position Sensor Correlation
Old Sep 29, 2006 | 10:04 PM
ckleen's Avatar
ckleen
1st Gear
Default PCM code p1221 Throttle Position Sensor Correlation
It is a 97 - This is the code what do I do next.
I have cleared it and it came back after about 3 miles.
Driving at 20 mph is not fun.
Clint
Old Sep 29, 2006 | 11:38 PM
DALE C's Avatar
DALE C
check the pins on the tp sensor if there is no problem there replace the TAC module 97's have a ton of TAC module problems there is an updated part available. Even if you dont need it now you will at some point
