Code not found- is it a real problem?
Old Sep 30, 2006 | 01:27 PM
CGintheC5's Avatar
CGintheC5
4th Gear
Default Code not found- is it a real problem?
Need someone's evil genius help here, I see an active (h and c) code under 10PCM of P0442 yielding a check engine light. I have checked the varied code decryption sites and can't find this one. I am hoping to go on a trip tomorrow (on my wedding anniversary) to the hills but am concerned about walking a great distance due to breakdown if this is a real problem. Any thoughts?
Old Sep 30, 2006 | 01:33 PM
quimbo's Avatar
quimbo
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
Check your gas cap that could be the gremlin
QUIMBO SEEYAAAH
Old Sep 30, 2006 | 05:23 PM
CGintheC5's Avatar
CGintheC5
4th Gear
Gotcha, thanks for the assist. It sounds benign enough that I don't see a problem w/the road trip tomorrow. i did check the gas cap and it seemed sealed , any other items I should check?
Old Sep 30, 2006 | 05:57 PM
quimbo's Avatar
quimbo
All cars after 95 have whats called system readiness test the code you have is most likely your gas cap. I dont remember but there is a cycle number when the car is turned on the system will pressurize the fuel system if it sences the slightest leak you will throw a P0442 code. 9 OUT OF 10 TIMES ITS THE GAS CAP!!!!! I would suggest getting a new cap and go from there. Im willing to bet thats your problem. Maybe we can ask a tech to chime in here to explain further. I dont see you having a problem with this code its just annoying so go on your trip and enjoy your anniversary
QUIMBO SEEYAAAH
Old Oct 1, 2006 | 10:17 AM
CGintheC5's Avatar
CGintheC5
4th Gear
Well that is good, I will check the seal on ye olde gas cap. Thanks very much for the help, definitely set my mind at ease.
Old Oct 1, 2006 | 10:52 AM
quimbo's Avatar
quimbo
Im always glad to help thats what i like most about this sight people are always willing to help when another member is in trouble. Enjoy your anniversary
QUIMBO SEEYAAAH
To Code not found- is it a real problem?
