Cylinder Heads
Old Oct 1, 2006 | 04:02 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Default Cylinder Heads
I've noticed a trend in the LS1 world being everyone uses CNC'd heads and no one seems to use hand finished heads on "gods motor."
I only ask because I can't help but think that one the majority of CNC heads being sold, both stock castings and aftermarket that some hand cleaning up or hand porting an as-cast set would yeild as good or better gains than the CNC programs when done right.
Thoughts?
Old Oct 1, 2006 | 04:40 PM
vettenuts's Avatar
vettenuts
CNC offers faster production and better reproducability from essentially hand ported heads. Usually a ton of research can be accurately reproduced on the CNC machine. If you read some of Tony's posts on the AFR heads, they spent a ton of time getting the flow they wanted from a small port and CNC is probably the only way to accurately reproduce it and get consistency from port to port as well as head to head.
Old Oct 1, 2006 | 07:26 PM
SpeedyZ's Avatar
SpeedyZ
But one of the biggest reasons you see so many CNC heads being used it because that is the way almost every aftermarket head comes. I'm sure the aftermarket head manufactures do a lot of research (hand porting) to get the good flow. Once they do they duplicate that with CNC. There is no way a head manufacture could pay a staff of good experienced hand porting people to hand port every head and still sell the heads at a reasonable price, so CNC is the only way to go for mass production. I'm not saying CNC is better than hand porting, just a lot cheaper and much faster. There is nothing wrong with hand ported heads. I'm sure most good experienced hand porting people could touch up a CNC head and get better flow, but your probably only talking 1-2%. So you have to say, is it worth the expense for that little gain. Most people will say that it is not and simply use the CNC heads as shipped.
Old Oct 2, 2006 | 12:53 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Well, I didn't mean finished from the factory by hand porters, I was talking more along the lines of someone taking a CNC'd or As-Cast head to an independent person to have them finish it off/improve things. Or is it that most people are just THAT complacent with the heads as they come from the manufacturer and the ones that do have things "finished off" simply don't talk about it?
Old Oct 2, 2006 | 01:06 PM
vettenuts's Avatar
vettenuts
I would think one could do more harm than good. For example, the Darts and the AFR's spent a lot of time on the flow bench. The Darts on a very expensive wet flow bench. A hand porter would likely not have access to the same tools or knowledge of the original design, so I would be reluctant to have someone modify the ports.
Old Oct 2, 2006 | 02:11 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
If you go to the wrong guy, sure, but (I'm going to throw out some names here) guys like Joe Prince, Phil@Advanced Induction, Port Pro's, E.B. Porting, Lloyd Elliott, ect. ect. KNOW what they're doing and have the proper equipment.
I will admit that a CNC has one DISTINCT advantage being that you KNOW that all ports are created equal, so there's going to be very little port variance. That's an inherent risk you take with hand finishing.
It just surprises me more than anything that (coming from the LT1 world) the ratio of CNC to hand finished setups is so one-sided.
To Cylinder Heads
