Head Selection
Old Oct 3, 2006 | 01:02 PM
Spikehorn's Avatar
Spikehorn
Default Head Selection
Rate your head selection for a street head/cam/header swap.
I'm assuming AFR's are the best, how do the others compare?
Old Oct 3, 2006 | 02:19 PM
zeevette's Avatar
zeevette
You know what happens when you assume........
Old Oct 3, 2006 | 06:21 PM
vettenuts's Avatar
vettenuts
For a street head, I would look for smaller port volume and good flow. Some of the ported heads have really big ports, but also big flow numbers.
Old Oct 3, 2006 | 08:59 PM
electronbluec5's Avatar
electronbluec5
My Z06 is getting a H/C package right now. I got a set of Trick Flow heads with a strong recommendation from people that know LS Motors. I got the 205 cc chambers
Old Oct 4, 2006 | 12:10 AM
Tsab's Avatar
Tsab
You may want to look into Cartek's ported 3x heads. Some of the cars are making north of 470 HP when combined with the 3x cam.
Old Oct 4, 2006 | 05:55 AM
vettenuts's Avatar
vettenuts
I didn't think the TFS heads were that small, I thought their smallest intake volume was the 215?
Old Oct 4, 2006 | 08:37 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Smallest TFS makes is 215. Did you get the TEA worked heads?? Those are nice. A LOT of potential.
Old Oct 4, 2006 | 09:33 AM
Spikehorn's Avatar
Spikehorn
Is there a price difference between the AFR heads and the Trick Flow?
Old Oct 23, 2006 | 08:42 PM
slayer6x6's Avatar
slayer6x6
I've been searching around about heads, it seems alot of people like the ported LS6 heads. Sounds like they are very streetable.
Old Oct 23, 2006 | 09:25 PM
99 vett babycar's Avatar
99 vett babycar
everybody likes thier heads best - do a search there's a ton of info out there, then decide for yourself. That's what I did and I ended up with AFR because I thought they were the best - but I could be wrong.
To Head Selection
