Intermittent Starter Problem?
Old Oct 3, 2006 | 04:54 PM
Staggerwing's Avatar
Staggerwing
6th Gear
Default Intermittent Starter Problem?
Please help...
2005 C5 Manual
Enter car, insert key, depress clutch pedal, turn key - "CLICK" from starter, no crank. Repeat, no crank. Repeat, car starts right up!?
Sometimes it doesn't happen at all, sometimes it may happen once, and sometimes it may take four attempts. Any suggestions?
Old Oct 3, 2006 | 06:52 PM
patton's Avatar
patton
St. Jude Donor '09
yer sure the click is from the starter? hows the batt? it sounds like starter
Old Oct 4, 2006 | 10:58 AM
Staggerwing
6th Gear
Default intermittent starter
Batt is new and fully charged. Pretty sure the sound is the starter (solenoid). I've heard this before on other vehicles I've owned over the last 35 years but I just have trouble believeing that a starter can go bad after only 30K miles; although the car is 6 years old!
Been through the stupid Steering Column Lock issue and have had the car towed three times for that - right now it's working. I'm a little disgusted with the C5 right now.
Staggerwing
Old Oct 4, 2006 | 12:32 PM
patton's Avatar
patton
St. Jude Donor '09
in the old days ya hit the starter with a hammer while someone tries to start it. dangerous on stick shift plus access to starter on vettes is limited. check all elect connections then if ya sure its starter clicking r+r it good luck
Old Oct 4, 2006 | 01:22 PM
timemender's Avatar
timemender
Could be as simple as damage to the solenoid due to arcing on the contacts that carry the heavy current directly to the starter motor.
First in electrical repair diagnosis is check ALL the electrical wire terminal connections. Proper connection cannot be determined by sight alone. The contact points of the wiring harness must be taken apart to be sure, especially with hidden corrosion. Even slight corrosion can cause problems, by impeding current flow.
Old Oct 4, 2006 | 04:53 PM
Staggerwing
6th Gear
Yeah, I'm thinking that corrosion may be the culprit too; it just "acts" that way. I'll crawl under her somehow and give it a good look. After reading a post earlier about disconnecting the battery and the dreaded "Service Steering Column Lock" code coming up on some dude, I wanna make sure I don't have to take out the battery for a starter replacement unless I have to.
Thanks for the help...
Old Oct 4, 2006 | 05:32 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
The first thing i would check is the clutch switch. There is a switch under the dash, that engages when push the clutch in. It lets the car know the clutch is in and it is ok to start. Make sure that is making contact before you get into the harder stuff
Old Oct 4, 2006 | 06:50 PM
ersatz928's Avatar
ersatz928
Check tightness of the battery cables to ground (frame rails), the braided ground links from the frame rails to the block, and the +12V cable to the bolt on the starter (many are loose)
Old Oct 5, 2006 | 04:28 PM
Staggerwing
6th Gear
Default intermittent starter problem
Will do. Have a late night tonight and tomorrow after work but can check stuff on the car on Saturday. Thanks for the tips!
Old Oct 5, 2006 | 04:39 PM
aquaholic's Avatar
aquaholic
replace the starter.
Old Oct 6, 2006 | 01:52 AM
bdiddo's Avatar
bdiddo
It's the starter... may last awhile but it's on it's out. been there, done that. sure hope you don't have headers or it will be pita to change
Old Oct 6, 2006 | 02:08 AM
NSTG8R's Avatar
NSTG8R
a) first and foremost .. dont listen to half the people here as they're speaking from experience on OTHER vehicles.
i had the same problem and it turned out to be the starter switch (the actual piece you stick the key in)
few things to check, a) battery b) clutch switch c) anti-theft relay under the pass. foot panel d) grounds e) the key switch f) the year of your vehicle cuz if it's an '05, its a button not a key insert
if all of those check out .. then it could be your starter .. i'd be more inclinded to check all of those before replacing your starter.
good luck. but my bet is on an electrical issue.
Old Oct 6, 2006 | 09:23 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
The other day my car wouldn't start... full batter, just got a "click" everytime I turned the key.
Well I had just finished my huge mod project which included R&I of the starter... well my buddy did that part b/c he's got smaller hands... well the main starter wire wasn't tight, more specifically the nut wasn't tight.
After removing the spark plugs and pulling the dipstick out I coudl finally fish a socket in there to get it tight... damn headers.
Now all is well.
So check the connections if you can.
To Intermittent Starter Problem?
