fuel tank question
Old Oct 5, 2006 | 07:22 AM
Aussie C5's Avatar
Aussie C5
Default fuel tank question
I purchased an 04 commemorative here in Australia. RHD. Awesome car, lots of looks. Have had a fuel leak at crossover connnection to left tank. Does anyone know where I can buy the o-rings inside this connector or better still where I can get a technical photo of this area and which way the o-rings go, as I think It's been taken out before. Would appreciate any feedback. Tony
Old Oct 5, 2006 | 11:58 PM
Wisdom's Avatar
Wisdom
Not sure if this helps you, but it may: http://www.corvetteactioncenter.com/....php?qstId=589 You may also want to search the forum for "fuel tank leaks" since there have been several threads on that topic. Good luck!
- Wisdom
Old Oct 6, 2006 | 07:14 PM
Aussie C5's Avatar
Aussie C5
Wisdom, Have checked that site before and will keep searching for the detailed drawing of it.
Old Oct 6, 2006 | 08:55 PM
Wisdom's Avatar
Wisdom
On my '04 I did have a fuel tank leak that caused the driver's tank to be replaced. At first the mechanic, at Corvettes of Houston, thought that those o-rings were bad so that's what he replaced. The tank still leaked as I discovered when I filled it a few hours later. After further research, they determined that the fuel tank itself had a problem and that's what they replaced. Evidently this is a problem with the 04's for some reason. There are several threads that discuss this. You may be seeing that problem.
- Wisdom
Old Oct 7, 2006 | 01:40 AM
Aussie C5's Avatar
Aussie C5
Great help, I will pressure test the tank now and it is the left tank too
To fuel tank question
