2000 C5, ABS module help
Old Oct 5, 2006 | 10:50 AM
NoOne's Avatar
NoOne
Default 2000 C5, ABS module help
My ABS pump/module which is located on the cross car frame rail in front of the engine has broken one of its mounting studs.
There are 2 studs on the driver side and a single on the passenger side.
That one is broke. For anyone who has had one of these off the car, is it a screw in stud? Can I replace it?
Old Oct 5, 2006 | 03:40 PM
white90conv's Avatar
white90conv
The two on the drivers side are held with nuts implying that they are studs in the unit. I cannot see the one on the passenger side. The manual says to remove 3 nuts. So I assume that the passenger side is also a stud in the unit.
Old Oct 5, 2006 | 08:49 PM
9T3JIM's Avatar
9T3JIM
All the studs actually consist of 2 pcs. Undo all the nuts and you can lift the entire abs unit up slightly. depending what is broke you see a steel collar and then a rubber bushing. Those two pieces slide off another stud that is attached to the EBCM. You should be able to get what you need from Karshop.
To 2000 C5, ABS module help
