HELP Another Problem
Old Oct 5, 2006 | 02:52 PM
11sec_C5Z51's Avatar
11sec_C5Z51
Default HELP Another Problem
When i'm on the highway, my coolant/engine temps are fine until i come to a stop. With the A/C off, at a stop, the engine temp only rises about 15 degrees to about 200 degrees F. On the highway it's about 185 degrees F. With the A/C on, at a stop, the temp shoots up to 240 degrees F, and on the highway it's 187 degree F with the A/C on. I have a 160* T-stats thats been in the car since Feb. '06 and the car is tuned for the T-stat.....What could be causing my car to overheat at a stop with the A/C on???
Old Oct 5, 2006 | 03:05 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You said your car was tuned for the 160 degee thermostat. Do you know if the fan temps were reprogrammed?
Also, as the outside temp starts to cool down, the A/C compressor (thus the fans) don't need to run as often. I had the same problem, until I reprogrammed my fan temps.
I think you really need to check into the settings for your FANS. It sounds like a simple reprogram would take care of your problem.
Old Oct 5, 2006 | 03:16 PM
Boob's Avatar
Boob
Fo sho a fan issue.
Old Oct 5, 2006 | 03:18 PM
Dirty Howie's Avatar
Dirty Howie
So its been fine all year and thru the hot summer months and has just now started ???
You checked for garbage blocking your condensor/radiator right ??
DH
Old Oct 5, 2006 | 03:40 PM
11sec_C5Z51
DH
no i haven't checked the condensor yet...where is it located? i cleaned out the front of the radiator so thats fine....
Old Oct 5, 2006 | 04:24 PM
brucemoose2's Avatar
brucemoose2
what fan settings do you recommend for a 160 stat? what do you recommend for a stock stat?
Old Oct 5, 2006 | 07:38 PM
Dirty Howie
That is the correct area ..... the A/C condensor sits in front of the radiator.
DH
To HELP Another Problem
