Compression and Pinging
Old Oct 8, 2006 | 11:20 AM
Kaseman's Avatar
Kaseman
Default Compression and Pinging
Just bought an '04 CE coupe. Prev owner stated heads were mildly ported and shaved .030". What is the stock compression and what might it be now? He also said the it had been tuned but it starts pinging pretty bad at about 3000 RPM. Running 93 octane. Shouldn't a tune have corrected this? Should I run a fuel additive?
Old Oct 8, 2006 | 11:22 AM
vettenuts's Avatar
vettenuts
Sound to me like the installed tune needs to be re-examined. Have you had it at the dealer at all recently, usually a tuner will correct this situation. Wonder if the dealer might have flashed out your custom tune. Otherwise start examining your usual culprits, vacuum leak, etc.
Old Oct 8, 2006 | 11:31 AM
Kaseman's Avatar
Kaseman
Has not been to dealer. I'm really unclear as to weather a tune was actually done. He said it was dyno tuned but the wideband O2 wasn't working. The he said it was street tuned. I don't know.
Old Oct 8, 2006 | 12:05 PM
Kaseman's Avatar
Kaseman
ttt
Old Oct 8, 2006 | 02:04 PM
Kaseman's Avatar
Kaseman
Anyone?
Old Oct 8, 2006 | 08:42 PM
vettenuts's Avatar
vettenuts
You really need to get it to a good tuner to check this out, also carbon will cause some pinging. Might be worth the decarb procedure as a start. Also, using FP60 will help keep future carbon build-up in check if that is your problem. These cars pull in a lot of oil from the PCV system, so carbon could be an issue.
Old Oct 8, 2006 | 10:38 PM
Kaseman's Avatar
Kaseman
Thanks vettenuts. The pvc has an oil catch can in line. I think it is most likely the tune. It has a vararam that was installed maybe after the previous tune. I have seen many threads where this was the concern.
Old Oct 9, 2006 | 08:44 AM
Mike04's Avatar
Mike04
Find a good local tuner and you shouldn't have any more problems
Old Oct 9, 2006 | 08:59 AM
vettenuts's Avatar
vettenuts
I would think the 04 might be more sensitive to this as well, isn't the MAF screenless or is that only the Z06?
Old Oct 9, 2006 | 11:50 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
The i read that the vararam can shift the a/f ratio lean, you probely need a re-tune.
Humanoid 2.0
My 04 LS1 has the screen.
Old Oct 9, 2006 | 01:03 PM
vettenuts's Avatar
vettenuts
OK, must only be on the Z06 then.
Old Oct 9, 2006 | 05:00 PM
Kaseman's Avatar
Kaseman
Thank you all. Any idea where I can get it tuned in the Hampton Roads or Richmond areas Virginia?
To Compression and Pinging
