L92/L76 402 Project
Old Nov 17, 2006 | 01:29 PM
  #101
WKMCD's Avatar
WKMCD
Guys, nobody is more anxious than me to get the car back. This is one of the very first in this configuration and we ran into a couple of NEW issues.
Relax, get a soda. We've posted every step of the way and will continue to do so.
Old Nov 17, 2006 | 02:37 PM
  #102
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Old Nov 17, 2006 | 10:33 PM
  #103
dads01dream's Avatar
dads01dream
Hey Phil,
Very impressive progress.... I didn't even realize you had a whole other career going on!!
Old Nov 17, 2006 | 10:36 PM
  #104
sams96's Avatar
sams96
Old Nov 18, 2006 | 10:36 AM
  #105
sams96's Avatar
sams96
Old Nov 18, 2006 | 06:08 PM
  #106
WKMCD's Avatar
WKMCD
Originally Posted by sams96
Lurk? Your car is right next to mine..
Sam, are you going to MIR tomorrow?
Old Nov 18, 2006 | 06:10 PM
  #107
sams96's Avatar
sams96
Don't know might try and take a day off.
Old Nov 20, 2006 | 07:02 PM
  #108
WKMCD's Avatar
WKMCD
And today's news is....
IT'S ALIVE!!!!!
Phil replaced the injector o-rings and fired it up last night.
Tuning starts tomorrow!!!
Old Nov 20, 2006 | 07:58 PM
  #109
dads01dream
Niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiice!!!! ! Can't wait to hear the tuning results. Hopefully you can put on a video clip too? :o
Old Nov 23, 2006 | 10:29 PM
  #110
Phil97SVT's Avatar
Phil97SVT
I dont know if anyone can help but here is the problem we're having....
Startup:
Engine cranks over normally and fires
RPMs go to 1500 and raise to 2000. Its sits there just fine.
After about 30 seconds we notice the headers will start to glow red, all 8.
Any throttle will send the car to 4k and won't return any lower...
1) The TB is CLOSED, verified by scanner and visual
2) The intake is plugged @ every port
3) We've sprayed carb cleaner on the injectors @ 2000rpm and no change in engine speed
4) We've sprayed carb cleaner around the ports @ 2000rpm and no change in engine speed.
The fact the headers get glowing red almost says either timing or injector timing is off.
Initally the car ran and had a high voltage Cam position sensor code and we found wires that looked like they should be swapped, swapped them and the code went away. Car idled normally but high.
With the timing set to 0 the RPMs still are 1700.
Old Nov 23, 2006 | 11:15 PM
  #111
90droptopp's Avatar
90droptopp
From: Murrieta Ca..... America, fun while it lasted
Startup:
Red headers..... it's way rich / not enough timing.
Old Nov 23, 2006 | 11:40 PM
  #112
Blue02ws6's Avatar
Blue02ws6
Startup:
I had that happen to mine after I got a mail order tune. It was in the throttle cracker table. They tuned it for a LS2 TB but i had a TPIS TB which they said it was different, I got the next tune back and it was much better with the AC off but with the AC on it did the same thing. Is the TB closed when it is reving at 4K? Might not be even the same thing but that is excatally how my car acted with the new tune. Everyone told me it was a vacuum leak but we couldn't find one.
Old Nov 24, 2006 | 07:46 AM
  #113
WKMCD's Avatar
WKMCD
I had a FAST/LS2 TB on the 346 and we're using the same TB on the 402. It ran great on the 346 so I don't think that's the problem.
Old Nov 27, 2006 | 06:51 PM
  #114
WKMCD's Avatar
WKMCD
UPDATE 11/27/06
After a week hair pulling, Phil discovered that the L76 intake was defective from GM and had major air leaks in the 3 internal support columns. They look like casting defects that slipped by GM QC (or is that an oxymoron)
The good news is I contacted the guy I bought it from and he's overnighting another one that he checked out before sending.
Phil should have it in the morning. New manifold Install and tuning will start in earnest tomorrow.
Old Nov 27, 2006 | 07:11 PM
  #115
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Very god to see!
Old Nov 27, 2006 | 09:26 PM
  #116
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
UPDATE 11/27/06
That would explain why I did not get a call on Sunday...
Peace
Chip
__________________
..................Click for
Old Nov 27, 2006 | 09:39 PM
  #117
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
UPDATE 11/27/06
Wow........wouldn't have seen that coming. Was Phil just chasing a hunch when he pulled the manifold for a look?
To L92/L76 402 Project
Old Nov 27, 2006 | 09:44 PM
  #118
WKMCD's Avatar
WKMCD
Probably..He'd already looked at everything else. This was not obvious.
Old Nov 28, 2006 | 09:41 PM
  #119
WKMCD's Avatar
WKMCD
Phil's got the replacement manifold going on tonight.
Old Nov 29, 2006 | 06:43 PM
  #120
peter pan's Avatar
peter pan
Life Time NCM #2196
Any news on the tune
