3:93 VS 4:10 gears
4:10's??
Currently I have a Vararam intake and LG pro headers and bullet exhuast?
Keeping up with the Joneses...
You will love the 3.90's. Feels like the gear the car should have come with.
Not enough miles on mine to have gotten on them yet either...
Peace
Willfulone
Now I am real glad I did not say I got them in and hammered the crap out of them...
Phil, I love them and they are performing outstanding...
Peace
Willfulone
I'm middle of the road kind of driver, like to go fast on highways and sometimes light to light!
I have a MN6, I'm told I'll get more use out of 6th. But don't want to shift 1 thru 4 too often, maybe 1 to 4 is now the way to go?
1. Planned RWHP
2. Driving style
1. Higher RWHP cars dont need higher gears. Lower rwhp cars can take full advantage of them though.
2. light to light, street driving, and 1/4 mile driving the 4.10s are great, but go to any HPDE and you will see that the 4.10s require way too much shifting.
I swaped from 3.42s to 4.10s because before all I did was 1/4 mile stuff, but then I got into HPDEs and had to switch to 3.73s to get the most out of the gear and to keep engine temps down.
Just think of your long term plans and then match the gears.
mine is a A4
thanks
Terry
mine is a A4
thanks
Terry
Phil
4:10's??
Are you looking for "Low End" torque (say, quarter mile speeds) or do you want “top-end” performance capability as well?
4:10 gears will give you a lot of off the line (traffic light to traffic light) torque and speed, but won’t do anything for sustained top end driving. With 4:10's you’ll be shifting gears a lot sooner and maxing out your RPMs as well with 4:10’s. If you're gonna "Drag Race" a lot and not us your Vette as a "Daily Driver" then 4:10's are your gears.
3:90 gears will give you faster off the line performance over your 3:42 gears for sure. Plus, you’ll retain more top end performance, but again you’ll reach your max engine RPM range sooner as you shift through the gears and your engine RPM’s will rev will be higher for gear as well.
3:73 gears will give you faster off the line performance over your 3:42 gears as well. You’ll maintain more top end performance also. Now, if you plan to do any engine modifications like adding a “Super Charger” later on then I wouldn’t go any higher than 3:73 gears.
For me, the 3:90 gears would be my pick. I’m over here in Germany where running on the “Autobahn” is a daily event at speeds between 120-160 mph are common place. “Top End” is King here in Germany ! If you can’t sustain at least 130 - 150 mph for an hour or so on the Autobahns, then you shouldn’t be driving a Corvette over here ! ! !
So, for me 4:10 gears wouldn’t work over here. Now, back there in the states where Speed Limits are restricted to way lower speed limets you can better utilize the "Taller" gears and still drive your Vette. But again, if you want a "Daily Driver" I would go with the 3:73's or 3:90's. .
Closing Comments: If you're a "Cruiser" like me and not a "Racer" I would get the 3:90’s, but that's just me. . .
Good luck on whatever setup you decide on. . . .
____________________________________
Cecil
Heidelberg, Germany
Germany-American Corvette Club
1999 C5 Coupe
LS6 Engine ~ (With Henrik's Auto Racing 475 HP Head and Cam Package)
